[Qgis-developer] keeping layer settings tab between layers and
qgis sessions can cause problems when histogram tab is the last viewed
Etienne Tourigny
etourigny.dev at gmail.com
Thu May 10 06:03:25 PDT 2012
You are right, that is the best approach. However, it might be best
to auto-load when the user actually switches to the tab.
A pain gdal does not have an API to query if the histogram is already
computed - this would require adding PAM-aware code to the gdal
provider.
Etienne
On Wed, May 9, 2012 at 9:53 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Generally it is good practice that the UI remembers where the user left it
> last time. In this case this has a bad user experience because of the slow
> loading. My suggestion would be to just add a "Load histogram" button in
> the histogram tab that loads the histogram rather then when the tab is
> switched to. This way even if the histogram tab is remembered as the
> current tab it will load like normal and user has to click "Load histogram"
> to show it.
> - Nathan
> On Thu, May 10, 2012 at 10:49 AM, Etienne Tourigny <etourigny.dev at gmail.com>
> wrote:
>> I agree that this should not happen, should the default be always open
>> the first tab, or only when the histogram tab was previously selected?
>> Unfortunately there is no function in the provider API to know if
>> there is a cached histogram, so it would be better to never allow the
>> properties window to start on the histogram tab.
>> I have implemented this in a branch of mine to improve the histogram
>> tab, here is a snippet:
>> - tabBar->setCurrentIndex( settings.value(
>> "/Windows/RasterLayerProperties/row" ).toInt() );
>> + int currentTabIndex = settings.value(
>> "/Windows/RasterLayerProperties/row" ).toInt();
>> + // if current tab is disabled, use first tab
>> + if ( ! tabBar->widget( currentTabIndex )->isEnabled() )
>> + currentTabIndex = 0;
>> + // if current tab is histogram, use first tab (to avoid long
>> histogram queries)
>> + // there is currently no way to know if there ia a cached histogram
>> int myHistogramTab = 6;
>> - if ( tabBar->currentIndex() == myHistogramTab )
>> - refreshHistogram();
>> + if ( currentTabIndex == myHistogramTab )
>> + tabBar->setCurrentIndex( currentTabIndex );
>> Etienne
>> On Mon, May 7, 2012 at 10:15 AM, G. Allegri <giohappy at gmail.com> wrote:
>> > A complex object to say something simple :(
>> > When a user opens a layer settings window and hits a tab, the same tab
>> > index
>> > is kept when opening another layer settings, or in a new qgis sessions.
>> > I had a small raster layer, and I opened the histogram tab.
>> > The today I've opened a big raster layer, and opening the layer settings
>> > caused my pc running and running, till a complete qgis crash.
>> > I supposed it was something with the settings, so I opened the smalle
>> > raster, changed the tab to Style, then I was able to open the large
>> > raster
>> > settings
>> > It's corner case probably, and qgis shouldn't crash with huge raster
>> > histograms. Anyway, opening the layer settings to the frist tab would
>> > avoid
>> > heartbreaks :)
>> > giovanni
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
