[Qgis-developer] Fwd: Threads in sextante
Victor Olaya
volayaf at gmail.com
Sun May 13 14:13:04 PDT 2012
Here is my opinion on all that, in short:
-The main idea of using threads is not now to execute multiplep
algorithms at the same time, so we can remove a lot of complexity
(like 2 processes writing the same file, as it was mentioned)
-Implementing a canceling mechanism is going to be the greatest
improvement once we have the threading stuff
-So, for me, this is what should be done:
1)implementing the threading part
2) implement the cancelling mechanism (a responsive cancel button, etc)
3) modifying algorithm to respond to cancellin events.
I think that would be more than enough for a first part, and it would
be a great improvement for SEXTANTE
Regards
p.s. Just to let you know, I am leaving for Honduras tomorrow, and
will be there working for 2 weeks, so I not might be very active on
the lists during the next 15 days or so
2012/5/13 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
> Hi Alex
>>Also I think about rewritting fTools in C++ and integrating its
>>algorithms into QGIS
>>analysis library. This makes tools a bit faster and will allow to use
>>algorithms in
>>plugins
> That would be a great enhancement and leverage the analysis library as a
> whole.
> Regards,
> Marco
> On 13.05.2012 09:23, Alexander Bruy wrote:
>> Hi Etienne,
>> 2012/5/12 Etienne Tourigny<etourigny.dev at gmail.com>:
>>> I stand corrected then - I guess I was confusing it with ftools, which
>>> is blocking and does not spawn a process.
>>> Any way ftools could be adapted to use the same approach as gdaltools?
>> most fTools functions already implemented as threaded, but there are some
>> minor issues. I work on improving processes handing in fTools, and several
>> tools already don't block main QGIS window, has non-modal dialogs and
>> allows
>> to cancel running process.
>> algorithms in
>> plugins
> Dr. Marco Hugentobler
> Sourcepole - Linux& Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Qgis-developer mailing list
