[Qgis-developer] Re: Removing old labelling
kfj
_kfj at yahoo.com
Mon May 14 11:17:02 PDT 2012
Nathan Woodrow wrote
> Any objections for removing the old labelling stuff?
> Is there anything the old one can do the new one can't?
I have several issues with the new labelling engine.
- I can only set an angle if I also set x and y coordinates (which I have to
artificially add as fields to my data, since they are only in the geometry
initially)
- the labels aren't placed precisely where they should be
- and, finally, as I noted just now, I can't create upside-down labels, as I
have described in
http://hub.qgis.org/issues/5593
I'd propose the new labelling engine is worked over. I have seen others
complain that it doesn't do as they expect. I can't use it for the reasons
given above, so I'd have a hard time if the old engine was removed.
Kay
View this message in context: http://osgeo-org.1560.n6.nabble.com/Removing-old-labelling-tp4546541p4974532.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
