[Qgis-developer] Discussion on browser and file extensions
kimaidou
kimaidou at gmail.com
Tue May 22 09:23:48 PDT 2012
Hi all
+1 for optionnal additionnal column, as it will be consistent for all use
cases, and leave the choice to the user.
Michael
2012/5/22 Etienne Tourigny <etourigny.dev at gmail.com>
> On Tue, May 22, 2012 at 4:10 AM, Giovanni Manghi
> <giovanni.manghi at faunalia.pt> wrote:
> > Hi,
> >> I think the discussion on http://hub.qgis.org/issues/5621 deserves
> more general
> >> discussion on this ML. Opinions? Could reporters make a short resume
> for us?
> I guess the consesus in the issue is that the browser should display
> extension names, and that there should be an *optional* indication in
> the legends layer as to the provenance.
> However, any other display/tool (drop to DB manager and PG/spatialite
> in browser) should not use the extension.
> It was also mentioned that drop from browser should be consistent with
> "Add Layers" dialog (and also from the commandline). It is not
> currently in the case of vector layers.
> These alternatives have been presented, perhaps needing a user option:
> 1) Always adding the extension and stripping it where necessary
> 2) Never adding the extension and adding it in the legend
> 3) Never adding the extension
> 4) the legend could have an optional (for experts) additional column
> with data source format.
> 1) and 2) deal more with a technical aspect in that the display name
> is set in QgsDataItem (by the QgsDirectoryItem in the browser case),
> so selectively changing that name based on the destination requires
> some consideration on the source (probably the uri + provider would be
> sufficient).
> Consensus on having the extension in the browser means that the
> QgsDataItem name must have the extension, but this must be removed
> when doing most D&D operations, which means more complexity.
> The alternative is to add the extension in the Browser (and possibly
> legend) based on the URI or perhaps a new member variable.
> Radim's solution to have an additional column specifying the
> datasource format (TIF, SHP, PG, etc.) is interesting, but might add
> clutter?
> > I originally asked to avoid leave the extension while dragging and
> > dropping from the browser, mainly because when dropping into DB Manager
> > it is annoying to have to manually remove that ".shp" (example) from the
> > suggested table name.
> > On the other hand seeing the datatype in the TOC is useful and a thing
> > that many users have asked in the past.
> > Real life projects tend to be large, with many layers from many
> > datasources/types. Vectors are not just vectors, and rasters are not
> > just rasters: there are vectors that cannot be edited (lack of
> > permission or because gdal does not allow it), layers that cannot be
> > used as input by standard qgis tools (GRASS rasters), etc.
> > Sometimes the users have even layers with the same name but of different
> > type.
> > So, seeing the format in the TOC is a step forward in usability, and in
> > the ticket were suggested a few ways to get it.
> > cheers!
> > -- Giovanni --
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120522/c7b8878e/attachment.html
