[Qgis-developer] problems printing with qgis web client
Giovanni Manghi
giovanni.manghi at faunalia.pt
Tue May 22 09:33:04 PDT 2012
Hi all,
I'm having some problems with the PDF generated by the qgis web client.
I set up the application with qgis-server master and the sample dataset
http://mapserver.uevora.pt/qgis-web-client/site/qgiswebclient.html?map=/var/www/qgis-web-client/projects/helloworld.qgs&format=image/png&visibleLayers=Hello,Country
printing up to 1:100.000 it is ok
more or less at 1:50.000 the layout in the pdf is wrong (the map object
is bigger than supposed and exits the page margins + the extent also
seems wrong)
starting from 1:50.000 the layout seems ok but the map object is empty
in the pdf.
Any suggestion?
cheers!
-- Giovanni --
