[Qgis-developer] problems debugging my plugin
SJWC GIS
sjwcgis at gmail.com
Wed May 23 10:28:01 PDT 2012
Thanks Denis. That's very helpful. After some poking around this morning,
I found my issue. I'm not sure why it was happening, but whenever my I
bound my new qcompleter object to the textbox, the application crashed.
Changing out the QLineEdit's QCompleter object isn't the preferred method
for working with dynamic content, but at the time it was the only one I
could get to work at the time. This morning I started using a
QStringListModel to store the list for the QCompleter, and I update that
instead now. The result has been much better, as the application no longer
crashes. Thanks again!
Aaron
On Tue, May 22, 2012 at 10:21 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
> Hi,
> If you run QGIS from the terminal / command window and place some "print"
> in your code, you'll see the result in the terminal.
> Hope it helps to start.
> On 05/23/2012 12:31 AM, SJWC GIS wrote:
>> Perhaps a way to output to the console?
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120523/301f735d/attachment.html
