[Qgis-developer] Problems to read ECW files
Giovanni Manghi giovanni.manghi at faunalia.pt
Thu May 24 06:51:17 PDT 2012
> I use QGis 1.8 on Xubuntu 32bit Precise 12.04 and I can't read ECW files...
> If you have a answer I would be very grateful.
you must add the ecw support to your gdal using the old er-mapper sdk.
It is quite easy to do that with the "libgdal-ecw" package in the
ubuntugis repository, too bad that the "precise" repo does not have yet
most of the packages, including this one.
cheers
-- Giovanni --
