[Qgis-developer] Library linking problems when release changes -
eg. 1.9 --> 1.8
kimaidou
kimaidou at gmail.com
Fri May 25 00:30:31 PDT 2012
Hi Andreas
I ran into the same problem, and wrote a "Tip" here, thanks to the help of
someone in the chan irc
http://hub.qgis.org/projects/quantum-gis/wiki/Building_QGIS_from_Source
2012/5/25 Andreas Neumann <a.neumann at carto.net>
> Hi,
> Whenever there is a change in the major version of QGIS, e.g. 1.7 to 1.9
> and most recently the switch back from 1.9 to 1.8 I am running into
> problems.
> The compile runs fine but when I try to start it I get this message:
> error while loading shared libraries: libqgis_core.so.1.8.0: cannot open
> shared object file: No such file or directory
> But the libqgis_core.so.1.8.0 is present in /usr/local/lib
> I removed the build directory and ran ccmake .. and cmake .. again, but it
> doesn't solve this problem that it can't find the library that obviously is
> present and recent on my machine.
> I would very much appreciate if someone could help me out here.
> Thanks a lot,
> Andreas
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120525/73d49e29/attachment.html
