[Qgis-developer] Discussion on browser and file extensions
Giuseppe Sucameli brush.tyler at gmail.com
Sun May 27 16:36:27 PDT 2012
Hi Etienne,
On Sun, May 27, 2012 at 11:37 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Can you look at this and if possible commit it before 1.8 is released?
I've just added a note to the pull request.
Regards.
> https://github.com/qgis/Quantum-GIS/pull/151
> Etienne
> On Fri, May 25, 2012 at 1:09 PM, Etienne Tourigny
>> On Fri, May 25, 2012 at 12:41 PM, Giuseppe Sucameli
>> <brush.tyler at gmail.com> wrote:
>>> Hi Etienne,
>>> On Fri, May 25, 2012 at 5:08 PM, Etienne Tourigny
>>>>> BTW we need another method, right? Something like
>>>>> QgsLayerItem::layerName()
>>>> This is the approach in my patches, only it is also supported in
>>>> QgsDataItem (see below why).
>>> IMHO it isn't.
>>> In your patch the fileName method is used to get the name
>>> displayed in the browser (see QgsBrowserModel::data() line 153),
>>> instead in my proposal the QgsLayerItem::layerName() would be used to get
>>> the name of the layer to load (not the filename).
>>> You should keep the QgsDataItem::name() for filename (data shown
>>> in the browser) and add a new method for QgsLayerItem::layerName().
>> ah ok, so name() would return the filename, whereas layerName() would
>> return the filename without extension, to be used in the drag&drop
>> operations. Sounds reasonable.
>> Would need to modify mime data stuff also, in QgsMimeDataUtils::Uri
>> what about file-based datacollection items? I guess only the layers
>> can get dropped to other targets, therefore no need to change
>> anything?
>>> BTW, I'm wondering if Radim meant the same.
>>>> Also, this could use uri() like you suggested instead of path(), not
>>>> sure I understand the distinction
>>> URI is the string used to load a layer, path is a way to identify a
>>> qgsdataitem in the browser tree.
>> ah ok, thanks
>>> Cheers.
>>>> QString QgsDataItem::fileName() const
>>>>  QFileInfo fileInfo( path() );
>>>>  return fileInfo.isFile() ? fileInfo.fileName() : name();
>>>> Again, this works in the default case, but the function should be
>>>> overloaded for efficiency in the case of gdal ang ogr /vsizip files
>>>> (like I did in my patches)
>>>> Regards,
>>>> Etienne
>>>>>> QgsDataItem is base for various data sources, most of them are not
>>>>>> file based.
>>>>> I agree, having a fileName() method in the QgsDataItem class
>>>>> is non-sense.
>>>> Well unless mistaken, you could have a QgsDataCollectionItem which is
>>>> file-based, such as multi-layer shape or qml?
>>>>> Cheers.
>>>>> Giuseppe Sucameli - Faunalia
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Giuseppe Sucameli
Giuseppe Sucameli
