[Qgis-developer] QGIS' "fetch python plugin" does not see my plugin
Bruno Combal
bruno.combal at gmail.com
Tue May 29 03:48:24 PDT 2012
Thanks Agustin!
I did not realize I had to add http://plugins.qgis.org/plugins/plugins.xml
to my repositories list.
Why not adding this repository in the default list? Security reason?
thanks again
Bruno
Le 29 mai 2012 à 12:18, Agustin Lobo a écrit :
> Bruno,
> I do see (and have installed) Earth Beat 0.75
> (qgis 1.7.4 on ubuntu 10:04)
> Do you have
> as repo ?
> Agus
> 2012/5/29 Bruno Combal <bruno.combal at gmail.com>:
>> Dear all,
>> I've made a little plugin, Earthbeat, still in experimental phase.
>> The plugin is hosted on http://plugins.qgis.org/plugins/
>> My problem is that the plugin does not show in QGIS "fetch python plugin" panel
>> (I turned on the "show all plugins, even those marked as experimental").
>> Could someone tell me what I should do to allow the plugin-fetch command
>> to retrieve my plugin from plugins.qgis.org?
>> To give more details:
>> 1. I sent the plugins as a zip for approval.
>> 2. after approval, zip was visible on http://plugins.qgis.org/plugins/
>> but not in the QGIS fetch command.
>> 3. I made a git repository, thinking (wrongly) that it would help
>> http://hub.qgis.org/projects/earthbeat/repository
>> My codes come with a metadata.txt file indicating the location of the git repository.
>> Maybe I should not have both zip+git?
>> Or are there some permissions to fix?
>> thanks!
>> Bruno
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
