[Qgis-developer] QGIS' "fetch python plugin" does not see my plugin
Etienne Tourigny
etourigny.dev at gmail.com
Tue May 29 07:12:52 PDT 2012
You can have it added by clicking "Add 3rd party repos.." button in
the Repositories tab of the plugin manager, this adds quite a few.
On Tue, May 29, 2012 at 7:48 AM, Bruno Combal <bruno.combal at gmail.com> wrote:
> Thanks Agustin!
> I did not realize I had to add http://plugins.qgis.org/plugins/plugins.xml
> to my repositories list.
> Why not adding this repository in the default list? Security reason?
> thanks again
> Bruno
> Le 29 mai 2012 à 12:18, Agustin Lobo a écrit :
>> Bruno,
>> I do see (and have installed) Earth Beat 0.75
>> (qgis 1.7.4 on ubuntu 10:04)
>> Do you have
>> as repo ?
>> Agus
>> 2012/5/29 Bruno Combal <bruno.combal at gmail.com>:
>>> Dear all,
>>> I've made a little plugin, Earthbeat, still in experimental phase.
>>> The plugin is hosted on http://plugins.qgis.org/plugins/
>>> My problem is that the plugin does not show in QGIS "fetch python plugin" panel
>>> (I turned on the "show all plugins, even those marked as experimental").
>>> Could someone tell me what I should do to allow the plugin-fetch command
>>> to retrieve my plugin from plugins.qgis.org?
>>> To give more details:
>>> 1. I sent the plugins as a zip for approval.
>>> 2. after approval, zip was visible on http://plugins.qgis.org/plugins/
>>> but not in the QGIS fetch command.
>>> 3. I made a git repository, thinking (wrongly) that it would help
>>> http://hub.qgis.org/projects/earthbeat/repository
>>> My codes come with a metadata.txt file indicating the location of the git repository.
>>> Maybe I should not have both zip+git?
>>> Or are there some permissions to fix?
>>> thanks!
>>> Bruno
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
