[Qgis-developer] Python support in project file
    Giuseppe Sucameli
    sucameli at faunalia.it
    Wed May 30 17:49:47 PDT 2012
Hi Martin,
On Wed, May 30, 2012 at 11:37 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> On Wed, May 23, 2012 at 9:24 PM, Giuseppe Sucameli
> <brush.tyler at gmail.com> wrote:
>> I've added a new tab "Project routines" to the project properties dialog
>> where the user can define 3 different python routines:
> Maybe I would call it "macros" - everyone knows that term from Excel
> and Word :-)
+1 for macros
> How the GUI is going to look like? Should the user enter the Python
> code directly into some text edit widgets?
yes, 3 text edit widget, one for each macro.
The user has to write python code into them.
> How are you going to save the python code? In an external file or
> embedded into XML file or even something else?
I would save it into the project (embedded in the XML) until we will
have a different way to pack project and related stuff together.
>> I'm also adding a safe-check, it asks to the user if enabling them.
> Good, it would be good to have the check done in a way that does not
> disturb the user with some popups - ideally something like a "yellow"
> bar that currently browsers use when asking questions.
I guess you're thinking to macros that make changes to the UI so
it doesn't matter when the macro is executed,
but IMHO this kind of macros should behave like a plugin connected
to the projectRead() signal, so bound to a specific event and executed
just after the event occurs.
BTW one popup only would be needed, i.e. the project is loaded.
If the user trust macros then they become active and ready to be
executed.
>> 2. In a loaded project with trusted scripts (the user has trusted them)
>> if the user changes their definitions from project properties dialog
>> 2.a. should the new routines become active immediately when the user
>> clicks on the apply button in the project properies dialog,
>> 2.b. or should become active when he saves the project (the new
>> projectSaved script has to be called just after the project is saved),
>> 2.c. or should I keep the previous ones until the project is reloaded?
> I would vote for 2.a: in fact when the user applies changes done to
> the python code, the python stuff could get reloaded, i.e. unload
> (from old code) would be called, followed by load (from new code) - I
> hope this will make the transition quite smooth.
I would vote for 2.c instead, but now I understand we aren't so aligned
as I thought :-)
For you macros should be like a plugin embedded in the project file,
so load and unload method, enabled asynchronously, ... (am I right?)
I guess in that case it doesn't matter if the project saved macro exists,
it could be just a iface signal the embedded-plugin load method
connects itself to.
For me they are project macros, hence strictly related to the project
events, i.e not a plugin but slots (routines) connected to signals (project
events), it has to be enabled synchronously and then a project saved
macro makes sense.
Project plugin VS. Project macros:
there's a difference, even although it seems more theoretical than
practical :-)
What do you think about?
Regards.
Giuseppe Sucameli - Faunalia
