[Qgis-developer] Python support in project file
Martin Dobias
wonder.sk at gmail.com
Wed May 30 23:30:13 PDT 2012
On Thu, May 31, 2012 at 2:49 AM, Giuseppe Sucameli <sucameli at faunalia.it> wrote:
>> How the GUI is going to look like? Should the user enter the Python
>> code directly into some text edit widgets?
> yes, 3 text edit widget, one for each macro.
> The user has to write python code into them.
I would prefer to have just one edit widget with all macros inside.
With 3 text edit widgets it would be complicated to have some common
utility functions, module imports etc. With one edit widget there
could the three predefined functions called by QGIS:
def openProject(...):
pass
def saveProject(...):
pass
def closeProject(...):
pass
Like this it would be easier to add custom imports, utility function
and it would be simpler to navigate the code (if there are more than
just few lines).
>> How are you going to save the python code? In an external file or
>> embedded into XML file or even something else?
> I would save it into the project (embedded in the XML) until we will
> have a different way to pack project and related stuff together.
Ok - hopefully XML will not choke python indentation :)
> BTW one popup only would be needed, i.e. the project is loaded.
> If the user trust macros then they become active and ready to be
> executed.
See Nathan's post - he better explains what I have meant.
> For you macros should be like a plugin embedded in the project file,
> so load and unload method, enabled asynchronously, ... (am I right?)
> I guess in that case it doesn't matter if the project saved macro exists,
> it could be just a iface signal the embedded-plugin load method
> connects itself to.
> For me they are project macros, hence strictly related to the project
> events, i.e not a plugin but slots (routines) connected to signals (project
> events), it has to be enabled synchronously and then a project saved
> macro makes sense.
> Project plugin VS. Project macros:
> there's a difference, even although it seems more theoretical than
> practical :-)
For me the project macros are really not that different from plugins -
they have just different lifetimes.
Regards
Martin
