[Qgis-developer] undefined symbol: _ZNK11QgsMapLayer3crsEv
Giuseppe Sucameli brush.tyler at gmail.com
Thu May 31 07:34:59 PDT 2012
Please, send the message to the list, this kind infos can be useful
to other people have the same problem.
On Thu, May 31, 2012 at 3:00 PM, Bernhard Ströbl
<bernhard.stroebl at jena.de> wrote:
> I basically followed
> http://hub.qgis.org/projects/quantum-gis/repository/revisions/master/entry/INSTALL
> to install into $HOME/apps
> only recently did I change the CMAKE_INSTALL_PREFIX to /opt/qgis-1.8.0
Building and installing from source may keep old stuff in the
previous installation path.
If you don't want that such kind of problems occur you should
consider to uninstall QGis (make uninstall) before compiling it again.
> I ran ldd /opt/qgis-1.8.0/bin/qgis | grep "libqgis" and got this:
> libqgis_core.so.1.8.0 => /home/StroeblB/apps/lib/libqgis_core.so.1.8.0
> (0x00007fa8e9291000)
> libqgis_gui.so.1.8.0 => /home/StroeblB/apps/lib/libqgis_gui.so.1.8.0
> (0x00007fa8e8d90000)
> libqgis_analysis.so.1.8.0 =>
> /home/StroeblB/apps/lib/libqgis_analysis.so.1.8.0 (0x00007fa8e8aef000)
> so obvoiusly it is not sufficient to only change the CMAKE_INSTALL_PREFIX?!
Shared lib are loaded by the OS, so old stuffs could blind new ones.
Anyway you could use the LD_LIBRARY_PATH enviroment variable
to override the path where to search libraries.
Ragards.
> Hi Giuseppe,
> thank you for your help. It turned out my build was linking to some older
> installation (at least as far as I understand).
> As I am not familiar with compiling software, may I ask you to help me
> understanding what was going on? I basically followed
> when I saw the tip at
> http://hub.qgis.org/wiki/quantum-gis/Building_QGIS_from_Source
> regards
> Bernhard
> Am 31.05.2012 11:43, schrieb Giuseppe Sucameli:
>> Hi Bernhard,
>> On Thu, May 31, 2012 at 9:28 AM, Bernhard Ströbl
>>> I compiled current master and got an error when starting QGIS:
>>> Traceback (most recent call last):
>>>  File "", line 1, in
>>> ImportError: /opt/qgis-1.8.0/share/qgis/python/qgis/core.so: undefined
>> remove the directory /opt/qgis-1.8.0/share/qgis/python/qgis/, it contains
>> old stuff (have a look at its modification date before).
>> Regards.
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
Giuseppe Sucameli
