[Qgis-developer] Sextante: vector to raster
Victor Olaya volayaf at gmail.com
Thu May 31 09:30:15 PDT 2012
> I'm trying to use Sextante to convert a vector to a raster, but:
> - GRASS v.to.rast does not work (ticket open)
Resolved in r198. Now there are 2 algs
> - GDAL rasterization is missing
True. Maybe it should be added
> - SAGA and OTB do not allow easily to use an existing raster to define extent and
> resolution (it is quite cumbersome to define it by hand).
To fill the extent field you can use the extent of a layer, just by
clicking on the button on its right-hand side and selecting "use
layer/canvas" extent. There you can select a layer or even the extent
of the current map view :-) To do this you need to have the parameters
dialog not in table mode, but in the complete mode (this can be set in
the configuration, in the "general" group)
Hope this helps
