[Qgis-developer] Manipulating JSON files from Python
Nathan Woodrow
madmanwoo at gmail.com
Wed Nov 14 05:10:21 PST 2012
Python has a builtin JSON module
http://docs.python.org/2/library/json.htmlwhich reads JSON into a
Python dict
- Nathan
On Thu, Nov 15, 2012 at 12:02 AM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi all,
> I would like to write small utility to manipulate metadata in a JSON
> file (for QGIS Webclient), like this one:
> http://webgis.uster.ch/qgis-web-client-dev/js/GISProjectListing.js
> The tool should import the JSON file, change some values and write it back.
> The idea would be to update, e.g. the time the data was last updated or
> other values.
> My questions:
> * what library should I use? SimpleJSON? Others?
> * Does someone have sample code around that does something similar?
> Thanks,
> Andreas
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121115/b3a567ac/attachment.html>
