[Qgis-developer] Server features
G. Allegri giohappy at gmail.com
Wed Nov 14 11:36:00 PST 2012
Actually, if performance is important a cache proxy should be used. I do it
with UMN Mapserver too.
With tile rendering, requested through MapProxy or similar WMS-T/TMS
server, we should provide metatiling and buffering. That would be needed by
the tile generator too, I suppose...
giovanni
2012/11/14 Vincent Picavet <vincent.ml at oslandia.com>
> Hi,
> > > The one thing were UMN Mapserver is a much better is performance. This
> > > is where we should really catch up.
> > I would put this to the higher position! I don't know where the effort
> > should be put, because I suppose it's something deep in the rendering
> > engine of QGis. Do you see bottlenecks at the server level?
> As for performances, the software stack used by QGIS is much fatter than
> the
> one used by Mapserver for instance.
> Using the QT framework is great for desktop applications, but degenerates
> performances when used in another context. Compared to QGIS, mapserver uses
> custom C implementation with thinner memory and computing resources
> management. This is valid for TinyOWS, mapcache and mapnik too.
> Ways to overcome this could be :
> * multithreading (but the catch-up will only work for a one-process
> architecture, mapserver can be parallelized since it's stateless)
> * using GPUs : that's a big task to implement
> This does not mean QGIS will alway be 10 times slower than mapserver and
> can't
> be improved, but it would be really surprised to see it keeping up with
> mapserver or mapnik performances.
> Vincent
> > I would also add a point to the whishlist: Qgis Server Python API ;)
> > giovanni
> > 2012/11/14 kimaidou <kimaidou at gmail.com>
> > > Hi
> > >> Hi,
> > >> > * templates for HTML popups (already done this in Lizmap, but why
> not
> > >> > having it in Qgis)
> > >> You mean accessing the templates through QGIS server ? Because html
> > >> popups already are in QGIS :)
> > > I mean through Qgis Server (in respect to this thread title ;)
> > > Just exposing methods for the server must do it, as Andreas proposed.
> > > We should have a look at PyWPS too, which could be an easy way to
> provide
> > >> WPS
> > >> services around QGIS API.
> > > Yes, pyWPS could help provide this feature, but we still need a way so
> > > that QGIS Server can use python plugins / processes, etc.. I remember
> > > discussion about this during last hackfests, but I do not know if
> someone
> > > gave it a try.
> > > Anyway, +10000 for focusing on performance first, which is the key
> > > "feature" for a Server.
> > > Michael
> > >> Vincent
> > >> > Good evening
> > >> > Michael
> > >> > 2012/11/14 G. Allegri <giohappy at gmail.com>
> > >> > > > - integrated tiling
> > >> > >> Why not integrating mapcache directly to mutualize effort on this
> > >> part ?
> > >> > >> Mapcache can be used standalone, and could read its parameters
> > >> directly
> > >> > >> from a
> > >> > >> qgis configuration file. No need to reinvent the wheel here, or
> > >> > >> would there be a
> > >> > >> good reason to it ?
> > >> > > I think that a tile generator from the QGis Desktop side would
> > >> suffice.
> > >> > > Any other TMS/WMS-T server could use the tile structure.
> > >> > >> > - mask layers
> > >> > >> That would be great to have in QGIS indeed. It would mean having
> > >> > >> for each layer an attached mask layer, which is not displayed but
> > >> > >> only
> > >> used
> > >> > >> to define
> > >> > >> hidden places.
> > >> > >> > - symbol placement
> > >> > >> > - label offsets
> > >> > >> That's for qgis symbology, not directly a qgis server issue.
> Label
> > >> > >> offset in
> > >> > >> mapserver definitly looks cool !
> > >> > > I agree Vincent.
> > >> > >> Vincent
> > >> > >> _______________________________________________
> > >> > >> Qgis-developer mailing list
> > >> > >> Qgis-developer at lists.osgeo.org
> > >> > >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121114/29607c80/attachment.html>
