[Qgis-developer] Manipulating JSON files from Python
Noli Sicad
nsicad at gmail.com
Wed Nov 14 23:49:33 PST 2012
Editing while reading in tablib - pull request
https://github.com/kennethreitz/tablib/pull/84
Noli
On 11/15/12, Pēteris Brūns <pb at sungis.lv> wrote:
> Probably in other case yes, but for Andreas required things better is to
> use python built in functionality and escape from external dependencies.
> Regards,
> On 2012.11.15. 09:34, Noli Sicad wrote:
>> This might help.
>> Tablib: Pythonic Tabular Datasets
>> http://docs.python-tablib.org/en/latest/
>> tablib.Dataset()
>> A Dataset is a table of tabular data. It may or may not have a
>> header row. They can be build and manipulated as raw Python datatypes
>> (Lists of tuples|dictionaries). Datasets can be imported from JSON,
>> YAML, and CSV; they can be exported to XLSX, XLS, ODS, JSON, YAML,
>> CSV, TSV, and HTML.
>> tablib.Databook()
>> A Databook is a set of Datasets. The most common form of a
>> Databook is an Excel file with multiple spreadsheets. Databooks can be
>> imported from JSON and YAML; they can be exported to XLSX, XLS, ODS,
>> JSON, and YAML.
>> Noli
>> On 11/15/12, gene <martin.laloux at gmail.com> wrote:
>>> see also json – JavaScript Object Notation Serializer
>>> <http://www.doughellmann.com/PyMOTW/json/> in the series "Python Module
>>> of
>>> the Week" of Doug Helmann. Sean Gillies (Shapely) also developed GeoJSON
>>> http://pypi.python.org/pypi/geojson/1.0.1
>>> <http://pypi.python.org/pypi/geojson/1.0.1> ) for geospatial purposes.
>>> For others implementations see
>>> http://pypi.python.org/pypi?%3Aaction=search&term=json&submit=search
>>> <http://pypi.python.org/pypi?%3Aaction=search&term=json&submit=search>
>>> As already mentioned, json, once loaded into Python is nothing more than
>>> a
>>> dictionary.
>>> View this message in context:
>>> http://osgeo-org.1560.n6.nabble.com/Manipulating-JSON-files-from-Python-tp5016253p5016491.html
>>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Pēteris Brūns
> SunGIS
> +371 26336691
> pb at sungis.lv
