[Qgis-developer] Server features
Andreas Neumann a.neumann at carto.net
Wed Nov 14 23:57:04 PST 2012
For 90% of my projects performance is really good. For the remaining
10%, rather complext projects, I would say it is good enough, but it
could be "snappier".
I am specifically talking about the "Leitungskataster" project, the
project displaying all supply lines and waste-water lines, containing
cadastral data, electricity, gaz, water, communication, waste-water and
heating.
These complex projects typically have:
* a lot of layers (around 70 layers)
* a lot of rules in the layer symbology
* automatically placed labels along lines
* dash patterns - almost all the lines are dashed
* SVG symbols
I will have to do my own homework. I will probably have to reduce the
number of layers by using views.
And to be honest, I haven't set up the same project on UMN mapserver to
compare whether it is really faster.
I don't know yet where the bottlenecks are (too many layers, too many
rules, too many rules, too many labels?).
Thanks,
Andreas
Am 14.11.2012 21:13, schrieb Marco Hugentobler:
> Hi all
> Performance is a complex topic, it essentially depends what you are
> testing ( few complex polygons, many small polygons, type of raster,
> lots of labels, ...).
> I'm regularly profiling some of my important server projects (e.g. WMS
> of cadastral survey). One thing that takes up a lot of render time is
> the drawing of the labels (only the rendering, not the placement).
> I think this is because they are rendered using QPainterPath and not
> with QPainter->drawText (but it might be difficult to render the buffer
> using drawText).
> And don't forget that normally the transfer of the image over the
> internet takes more time than the WMS rendering itself. So don't forget
> to use jpg for rasters and the improved png8 for vectors. It can improve
> perceived performance by a factor of 3 or 4.
> Regards,
> Marco
> On 14.11.2012 19:57, Andreas Neumann wrote:
>> Lets say that speed of QGIS Server is good enough for most of my
>> projects. But it could be faster for more complex rendering and labeling.
>> UMN feels faster than QGIS Server - but I don't have time for double
>> configurations for desktop and web. Plus - it is so much easier to
>> configure QGIS projects compared to editing mapfiles.
>> "G. Allegri" <giohappy at gmail.com> schrieb:
>>         The one thing were UMN Mapserver is a much better is
>>         performance. This
>>         is where we should really catch up.
>>     I would put this to the higher position! I don't know where the
>>     effort should be put, because I suppose it's something deep in the
>>     rendering engine of QGis. Do you see bottlenecks at the server level?
>>     I would also add a point to the whishlist: Qgis Server Python API ;)
>>     giovanni
>>     2012/11/14 kimaidou <kimaidou at gmail.com <mailto:kimaidou at gmail.com>>
>>         Hi
>>         2012/11/14 Vincent Picavet <vincent.ml at oslandia.com
>>         <mailto:vincent.ml at oslandia.com>>
>>             Hi,
>>             > * templates for HTML popups (already done this in
>>             Lizmap, but why not
>>             > having it in Qgis)
>>             You mean accessing the templates through QGIS server ?
>>             Because html popups
>>             already are in QGIS :)
>>         I mean through Qgis Server (in respect to this thread title ;)
>>         Just exposing methods for the server must do it, as Andreas
>>         proposed.
>>             We should have a look at PyWPS too, which could be an easy
>>             way to provide WPS
>>             services around QGIS API.
>>         Yes, pyWPS could help provide this feature, but we still need
>>         a way so that QGIS Server can use python plugins / processes,
>>         etc.. I remember discussion about this during last hackfests,
>>         but I do not know if someone gave it a try.
>>         Anyway, +10000 for focusing on performance first, which is the
>>         key "feature" for a Server.
>>         Michael
>>             Vincent
>>             > Good evening
>>             > Michael
>>             > 2012/11/14 G. Allegri <giohappy at gmail.com
>>             <mailto:giohappy at gmail.com>>
>>             > > > - integrated tiling
>>             > >> Why not integrating mapcache directly to mutualize
>>             effort on this part ?
>>             > >> Mapcache can be used standalone, and could read its
>>             parameters directly
>>             > >> from a
>>             > >> qgis configuration file. No need to reinvent the
>>             wheel here, or would
>>             > >> there be a
>>             > >> good reason to it ?
>>             > > I think that a tile generator from the QGis Desktop
>>             side would suffice.
>>             > > Any other TMS/WMS-T server could use the tile structure.
>>             > >> > - mask layers
>>             > >> That would be great to have in QGIS indeed. It would
>>             mean having for
>>             > >> each layer an attached mask layer, which is not
>>             displayed but only used
>>             > >> to define
>>             > >> hidden places.
>>             > >> > - symbol placement
>>             > >> > - label offsets
>>             > >> That's for qgis symbology, not directly a qgis server
>>             issue. Label
>>             > >> offset in
>>             > >> mapserver definitly looks cool !
>>             > > I agree Vincent.
>>             > >> Vincent
>>             > >> _______________________________________________
>>             > >> Qgis-developer mailing list
>>             > >> Qgis-developer at lists.osgeo.org
>>             <mailto:Qgis-developer at lists.osgeo.org>
>>             > >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail
>> gesendet.
