[Qgis-developer] QGis 1.8 Custom Feature Form
Justin Hubbard
justin at pyrotechsoftware.com
Tue Nov 27 22:31:11 PST 2012
Hi
I will try to modify the Sys.Path
The Form is in the same directory as the project though.
On Wed, Nov 28, 2012 at 8:12 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> You probably need to manipulate your sys.path to ensure that your form is
> visible to python at plugin start, or move your form into the same
> directory as your project file.
> Regards
> Tim
> On Mon, Nov 26, 2012 at 9:02 PM, Justin Hubbard <
> justin at pyrotechsoftware.com> wrote:
>> I am developing a plugin, which uses a custom feature form with custom
>> logic.
>> The problem is that when I open the project (Automatic with the load of
>> the plugin) and I try to open the feature form I get an import error that
>> the module doesn't exist.
>> If I click the save project button, and then try to open the feature form
>> it works correctly.
>> I have tried to trigger this save in the plugin code. The save works
>> correctly, but unless I specifically click on the action, I get the same
>> error.
>> Am I missing something?
>> Warm regards
>> *Justin Hubbard*
>> *Justin Hubbard*
>> Software Engineer and Support
>> Mobile:
>> +27 (0)79 827 1657
>> Fax:
>> +27 (0)86 540 6016
>> Email:
>> justin at pyrotechsoftware.com <robert at plannermunicipalsoftware.co.za>
>> Web Site:
>> www.pyrotechsoftware.co <http://www.plannermunicipalsoftware.co.za/>m
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
Warm regards
*Justin Hubbard*
*Justin Hubbard*
Mobile:
+27 (0)79 827 1657
Fax:
+27 (0)86 540 6016
Email:
Web Site:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121128/e468b597/attachment.html>
