[Qgis-developer] Update to the SpatiaLite provider
a.furieri at lqt.it
a.furieri at lqt.it
Fri Nov 30 08:49:52 PST 2012
On Fri, 30 Nov 2012 16:58:44 +0100, Giuseppe Sucameli wrote:
> Hi devs, hi all,
> Alessandro Furieri has sent to me a patch to support the features
> available from the newest SpatiaLite v4 into the provider, mostly
> the intensive use of statistics to improve performaces.
Giuseppe, thanks a lot for your precious collaboration.
> @Alessandro: please, could you tell us what's new in
> the provider? I know some details, but I'm sure devs would
> like to know more.
surely yes:
a) spatialite v4 is now strictly conformant to the most recent
OGC-SFS and ISO SQL/MM standard requirements.
unhappily this necessarily implies few compatibility breakages.
b) any recent version of libspatialite starting since 4.0.0 has
the capability to handle any DB created using any possible
previous version of the library.
this happens in a completely transparent way, and the user is
not required to apply any special precaution at all.
the full library support is available both on reading and writing,
and obviously covers the Spatial Index capabilities as well.
(see below for further details).
c) the opposite isn't true; it's absolutely impossible connecting
any new DB created using the most recent libspatialite 4.0.0 if
the underlying library is obsolete (any version < 4.0.0)
the revised QGIS data-provider will emit an appropriate error
message in this case (when linked against an obsolete library
version and attempting to open a DB-file created by a recenter
version).
d) a new CLI tool is make available in spatialite-tools-4.0.0:
"spatialite_convert" makes possible safely converting any DB-file
back and forward between v.2.3.x, v.3.0.x and v.4.0.x
it doesn't requires a full DB conversions, simply the metadata
tables are affected, so converting from a version to the the other
is a really fast process just requiring few seconds even when the
DB-file is a really huge and complex one.
e) the most recent DB layout supported by v.4.0.0 now supports a full
set of statistic infos; this is specially useful for QGIS, because
now the data provider can avoid at all to loose time by "sniffing"
each layer before connecting.
and this is obviously useful while connecting to some layer
containing
many million feature; the time required by any previous version of
the QGIS data-provider could require several minutes in this case.
now, when full v.4.0.0 support is available, just few seconds are
enough to connect such "huge layers".
f) last but not least: libspatialite v.4.0.0 now supports several API
methods taking full care to internally handle any metadata table
(e.g. the ones supporting the internal statistics).
such "abstract" methods are mainly intended to avoid any direct
physical
access from the data-provider itself.
so the data-provider can now completely ignore any fine-grained
detail
about the version-dependent DB layout; these "abstract API methods"
will
always implement the most appropriate access strategy to the
metadata
tables for any possible DB layout.
a strong commitment exist to fully preserve all these "abstract API
methods": so any future major change affecting the DB layout will be
completely transparent to the QGIS data-provider, and simply
upgrading
the underlaying libspatialite will be enough to keep anything
correctly
aligned.
g) just a final note: a further "abstract" API method will now support
full deletion of any Geometry table, taking care to remove any
possible
metadata reference and any Spatial Index eventually defined.
as a rule-of-the-thumb, the revised data-provider will continue to
work
exactly as before when linked against any libspatialite prior to
4.0.0
but will take full profit of the new "abstract" methods if linked to
libspatialite v.4.0.0 (or any subsequent).
if you are interested to learn more about these topics, here you can
find
the appropriate documentation:
https://www.gaia-gis.it/fossil/libspatialite/wiki?name=switching-to-4.0
bye Sandro
Il messaggio e' stato analizzato alla ricerca di virus o
contenuti pericolosi da MailScanner, ed e'
risultato non infetto.
