[Qgis-developer] qgis compilation in windows
Massimo
massimo.endrighi at geopartner.it
Mon Oct 1 09:58:02 PDT 2012
Is there anyone who can help me on qgis compilation in windows ?
I was able to compile version 1.8.x but now using latest repository version
[1.9.0 Master (10900)] I don´t.
Problems start with Project: python_module_qgis_networkanalysis as shown
below:
------ Build started: Project: python_module_qgis_networkanalysis,
Configuration: RelWithDebInfo Win32 ------
Generating analysis/network/sipnetworkanalysispart0.cpp,
analysis/network/sipnetworkanalysispart1.cpp,
analysis/network/sipnetworkanalysispart2.cpp,
analysis/network/sipnetworkanalysispart3.cpp
sip: Deprecation warning:
C:/develop/Gis/Quantum-GIS/python/analysis/network/networkanalysis.sip:1:
%Module version number should be specified using the 'version' argument
sip: Deprecation warning: C:/develop/Gis/Quantum-GIS/python/core/core.sip:1:
Compiling...
.\analysis\network\sipnetworkanalysispart1.cpp(338) : *error C2039:
'senderSignalIndex'* : is not a member of 'QObject'
C:\OSGeo4W\include\qt4\QtCore\qobject.h(122) : see declaration of
'QObject'
.\analysis\network\sipnetworkanalysispart1.cpp(338) : *error C3861:
'senderSignalIndex':* identifier not found
.\analysis\network\sipnetworkanalysispart1.cpp(1253) : *error C2039:
'QObject'
.\analysis\network\sipnetworkanalysispart1.cpp(1253) :* error C3861:
Generating Code...
Build log was saved at
"file://c:\develop\Gis\Quantum-GIS-build\python\python_module_qgis_networkanalysis.dir\RelWithDebInfo\BuildLog.htm"
python_module_qgis_networkanalysis - 4 error(s), 2 warning(s)
Cmake configuration is the following:
Quantum GIS version: 1.9.0 Master (10900)
Could not find GRASS
Found Proj: C:/OSGeo4W/lib/proj_i.lib
Found GEOS: C:/OSGeo4W/lib/geos_c_i.lib
Found GDAL: C:/OSGeo4W/lib/gdal_i.lib (1.9.1)
Found Expat: C:/OSGeo4W/lib/libexpat.lib
Found Spatialindex: C:/OSGeo4W/lib/spatialindex_i.lib
Found Qwt: C:/OSGeo4W/lib/qwt5.lib (5.2.1)
Found Sqlite3: C:/OSGeo4W/lib/sqlite3_i.lib
Found PostgreSQL: C:/OSGeo4W/lib/libpq.lib
Found SpatiaLite: C:/OSGeo4W/lib/spatialite_i.lib
Touch support disabled
Pedantic compiler settings enabled
Found Python executable: C:/OSGeo4W/bin/python.exe
Found Python version: 2.7.2
Found Python library: C:/OSGeo4W/apps/Python27/libs/python27.lib
Found SIP version: 4.14
Found PyQt4 version: 4.9.5
Found GSL: C:/OSGeo4W/lib/gsl.lib;C:/OSGeo4W/lib/cblas.lib
txt2tags not found - disabled
Ctest Binary Directory set to: C:/develop/Gis/Quantum-GIS-build/output/bin
Configuring done
Generating done
Thank you
View this message in context: http://osgeo-org.1560.n6.nabble.com/qgis-compilation-in-windows-tp5005634.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
