[Qgis-developer] QGIS Server WFS-T integration
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Oct 3 02:44:40 PDT 2012
Hi René-Luc
 >For the GML, I'll update QgsGeometry class ?
Yes, it will be good to have everything in one place (also for a
potential redesign of QgsGeometry). But the GML methods should not be
exported to the bindings, maybe you could add a comment in that
direction to qgsgeometry.h.
Regards,
Marco
On 03.10.2012 10:03, rldhont wrote:
> Hi Marco,
> I updated my branch with the definition of QGS_NAMESPACE and
> OGC_NAMESPACE.
> For Query_String, I found the code with a google search.
> I test WFS-T with a jQuery XML POST and with QGIS.
> Cheers,
> René-Luc D'Hont
> 3Liz
> Le 03/10/2012 09:26, Marco Hugentobler a écrit :
>> Hi René-Luc
>> Thank you for this nice addition, WFS-T will certainly be a great
>> contribution to QGIS server!
>> I tried to compile the wfs_server_transaction branch, but it fails
>> with the following error message (QGS_NAMESPACE and OGC_NAMESPACE are
>> not defined):
>> /home/marco/src/Quantum-GIS/src/mapserver/qgswfsserver.cpp:718:35:
>> Fehler: »QGS_NAMESPACE« wurde in diesem Gültigkeitsbereich nicht
>> definiert
>> /home/marco/src/Quantum-GIS/src/mapserver/qgswfsserver.cpp:721:39:
>> Fehler: »OGC_NAMESPACE« wurde in diesem Gültigkeitsbereich nicht
>> definiert
>> Maybe there is a commit that you did not push to github yet?
>> Then, looking at qgswfsserver.cpp, it seems that most of the 2000
>> code lines deal with GML. It would be good to separate that into a
>> GML handling class on its own (which could also be used from
>> qgswfsprovider, at the moment, the gml reading seems to be duplicated).
>> In QgsPostRequestHandler, the code looks for the environment variable
>> QUERY_STRING. I thought QUERY_STRING is only defined in http get
>> requests and in post requests, there is only CONTENT_LENGTH ?
>> Which WFS client did you use for testing (QGIS desktop)?
>> Regards,
>> Marco
>> On 01.10.2012 15:21, rldhont wrote:
>>> Hi all,
>>> I need some review for the WFS-T implementation in QGIS-Server.
>>> https://github.com/rldhont/Quantum-GIS/tree/wfs_server_transaction
>>> This branche adds the capability to the QGIS Server to understand
>>> transaction, adds a way to define which WFS layer can be editable
>>> and if the administrator authorize insert and delete, adds an
>>> enhancements for the WFS provider to support WFS-T which needs extra
>>> parameters.
>>> For the configuration on the WFS-T part, Update is possible if the
>>> layer is publish as a WFS layer, Insert is possible only if Update
>>> is possible and Delete is possible only if Insert is possible. You
>>> can check Delete on a layer and it's automatically a WFS layer, or
>>> uncheck Publied on a layer and all the checkbox are unchecked.
>>> I have testing QGIS-Server transaction with an ESRI ShapeFile and a
>>> Spatialite database. The both doesn't return a good FID, but only
>>> Spatialite has persistent FID. The Spatialite provider probably
>>> needs an update.
>>> I test my QGIS-Server with QGIS and some JavaScript code.
>>> René-Luc D'Hont
>>> 3Liz
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
