[Qgis-developer] license issues
Werner Macho werner.macho at gmail.com
Wed Oct 3 10:42:50 PDT 2012
Dear developers,
A long outstanding issue is (which is probably preventing QGIS from
being integrated into the "main" debian repository and the fedora
repository) that there are a lot of files inside our source tree that
have no or an unknown license with no copyright and so on ..
I took the freedom to make a short list and sort out all file which
have no license header ..
All in all I found 516 files without any license!
And bad news for Victor and sextante - 275 of them are in the sextante
subdirectories ;)
I encourage and kindly ask all developers who committed this files to
add a proper header to those files to get a bit closer of being
adopted into the main repositories of the big Linux distributions (not
to forget that having a copyright and license in the files is anyway a
good thing to have)
Find attached the list of the files (or if it does not go through the
server you can find the file in [1])
If you need any help drop me a note
thanks for your help
kind regards
Werner
[1] https://dl.dropbox.com/u/11824349/license.zip
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121003/8a06d287/attachment.zip>
