[Qgis-developer] New Python console: missing icons?
Salvatore Larosa
lrssvtml at gmail.com
Fri Oct 5 01:24:02 PDT 2012
2012/10/5 Giuseppe Sucameli <brush.tyler at gmail.com>
> Hi all, hi Salvatore,
> On Thu, Oct 4, 2012 at 6:01 PM, Werner Macho <werner.macho at gmail.com>
> wrote:
> > Not confirmed here .. everything looks fine .. compiled from latest
> > master 5min ago ..
> the problem [1] is confirmed: it's present in all the QGis
> installations that uses packages, both self-compiled or
> from repository (nightly).
> The issue is due to the current location of the console icons
> in the QGis source tree.
> I discussed together with Tim about the better way to fix it,
> we agree that console icons and help should be moved in
> the proper folders, i.e. respectively images and resources
> located in the source root.
I agree, regardless of the problem !
What the right place should be ?
> Salvatore, please could you fix it making a such change?
> Thanks.
I hope to do as soon as possible !
Regards,
-SL
> Regards.
> [1] http://hub.qgis.org/issues/6456
> > On Thu, Oct 4, 2012 at 5:49 PM, Paolo Cavallini <cavallini at faunalia.it>
> wrote:
> >> Il 04/10/2012 15:15, Nathan Woodrow ha scritto:
> >>> Yeah I have both those issues here too.
> >> Glad I'm not the only one. Just recompiled from master, the issue
> remains.
> >> Thanks.
> >> Paolo Cavallini - Faunalia
> >> www.faunalia.eu
> >> Full contact details at www.faunalia.eu/pc
> >> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Giuseppe Sucameli
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121005/396212ab/attachment.html>
