[Qgis-developer] index in self.legend.groupLayerRelationship - different behavior between QGIS 1.8 and master?
kimaidou
kimaidou at gmail.com
Fri Oct 5 05:41:48 PDT 2012
Hi all,
+ 1 for the proposal of Massimo using the DOM implementation. I will be
straightforward to use.
Michael
2012/10/5 Massimo <massimo.endrighi at geopartner.it>
> Etienne Tourigny-3 wrote
> > While it woulf be good to expose legend api to python, it mught be a
> > lot of work.
> Yes it could be a lot of work and I'm not sure about how to do it.
> > would it be sufficient to have the following?
> > 1) groups relations like this:
> > QList< QPair< int, QList < int > > >
> > 2) layers within a group like this:
> > QList< QPair< int, QList< QString > > >
> > or
> > QList< QPair< int, QList< QgsMapLayer* > > >
> > this way, you have access to group hierarchies by id, and layers for each
> > group.
> > You would use existing methods like setGroupExpanded() to work on
> > groups in a relatively simple manner.
> Using the index instead of group name is a good idea. Anyway, the groups
> relations could be recursive in order to avoid a "complex" algorithm to
> reconstruct the hierarchy.
> Furthermore splitting the information over two lists cuts off the exact
> sequence of layers/groups and any post processing logic will fail to
> Thus I propose another solution based on QDomDocument similar to the one
> adopted into the QgsLegend::writeProject method.
> The returned document will contain only groups and layers names and
> indexes,
> like the following example:
> <!DOCTYPE Group Layer Hierarchy>
> <Legend>
> <Group Name="G0" Index="0">
> <Layer GroupIndex="0" Id="L020120904162647883" Name="L0" Index="0"/>
> <Group Name="G1" Index="1">
> <Group Name="G2" Index="2">
> <Layer GroupIndex="2" Id="L120120904162647883" Name="L1" Index="1"/>
> <Layer GroupIndex="2" Id="L220120904162647382" Name="L2" Index="2"/>
> <Layer GroupIndex="2" Id="L320120904162644097" Name="L3" Index="3"/>
> </Group>
> <Group Name="G3" Index="3">
> <Layer GroupIndex="3" Id="L40120904162648624" Name="L4" Index="4"/>
> </Group>
> <Group Name="G4" Index="4">
> <Layer GroupIndex="4" Id="L520120904162649445" Name="L5" Index="5"/>
> </Group>
> </Group>
> </Group>
> </Legend>
> Massimo
> http://osgeo-org.1560.n6.nabble.com/index-in-self-legend-groupLayerRelationship-different-behavior-between-QGIS-1-8-and-master-tp5004337p5006614.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121005/10d264e9/attachment.html>
