[Qgis-developer] (no subject)
Volker Fröhlich volker27 at gmx.at
Fri Oct 5 07:46:25 PDT 2012
On Fri, 2012-10-05 at 17:25 +0530, SIVA RAMA KRISHNA wrote:
> Hello all,
>             I am trying to build qgis(1.8.0) for Qt in fedora17
>            I have  INSTALLED dependies for  Python
> pyqt(-x11-gpl-4.9.5]) and sip(-4.13-1.fc16.x86_64)
>           It is building upto following Steps
> Scanning dependencies of target python_module_qgis_networkanalysis
> [ 92%] Building CXX object
> python/CMakeFiles/python_module_qgis_networkanalysis.dir/analysis/network/sipnetworkanalysispart0.cpp.o
> python/CMakeFiles/python_module_qgis_networkanalysis.dir/analysis/network/sipnetworkanalysispart1.cpp.o
> python/CMakeFiles/python_module_qgis_networkanalysis.dir/analysis/network/sipnetworkanalysispart2.cpp.o
> python/CMakeFiles/python_module_qgis_networkanalysis.dir/analysis/network/sipnetworkanalysispart3.cpp.o
> Linking CXX shared library ../output/python/qgis/networkanalysis.so
> [ 92%] Built target python_module_qgis_networkanalysis
> [ 92%] Generating ui_qgsplugininstallerbase.py
>       Any Help for the above Problem is greatly apprieciated
>   Thanking You
> Qgis-developer mailing list
Why don't you just use the Fedora packages?
Volker
