[Qgis-developer] updating pyspatialite on windows
Paolo Cavallini cavallini at faunalia.it
Mon Oct 15 13:34:47 PDT 2012
Why using an old QGIS?
PIERRE Sylvain <sylvain.pierre at cg67.fr> ha scritto:
>Hi,
>I would like to update the pyspatialite library in Python :
>Windows 7
>Qgis 1.7
>I 've downloaded last package available (3.01), assuming QGis 1.7
>version is 2.6.2.
>I'm using gcc (cygwin) to compile.
>After solving some problems, I'm stuck !
>I think it's a path format (Unix / Dos) conflict :
>python setup.py build --compiler=mingw32
>C:\cygwin\bin\gcc.exe -mno-cygwin -mdll -O -Wall
>-DMODULE_NAME=\"spatialite.dbapi2\" -DVERSION="3.0.1"
>-DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1
>-DSQLITE_ENABLE_COLUMN_METADATA=1 -DOMIT_FREEXL=1
>-I/Library/Frameworks/GEOS.framework/unix/include/
>-I/Library/Frameworks/PROJ.framework/unix/include/ -Iamalgamation
>"-IC:\Program Files\Quantum GIS Wroclaw\apps\Python25\include"
>"-IC:\Program Files\Quantum GIS Wroclaw\apps\Python25\PC" -c
>src/module.c -o build\temp.win32-2.5\Release\src\module.o
>gcc: Files\Quantum : No such file or directory
>gcc: GIS : No such file or directory
>gcc: WroclawappsPython25include -IC:Program : No such file or directory
>gcc: WroclawappsPython25PC -c src/module.c -o
>build\temp.win32-2.5\Release\src\module.o : No such file or directory
>gcc: pas de fichier à l'entrée
>error: command 'gcc' failed with exit status 1
>Windows backslash deasepered.
>Any help should be welcome...
>_______________________________________________
>Qgis-developer mailing list
>Qgis-developer at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-developer
http://faunalia.it/pc
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121015/d321933c/attachment.html>
