[Qgis-developer] R Sextante error
Victor Olaya
volayaf at gmail.com
Sat Oct 20 07:53:37 PDT 2012
Agustin,
There are a few importante changes since last version, but I would
like to close a couple of bugs before releasing a new version. The
patch, I will apply it today and it will be in the github repo.
In short, I guess you can count on a new version in less than a month
(there is not a well defined roadmap at the moment, but that is a good
estimate). If you want to always have the most recent version (with
unstable stuff as well...), using the github version is the
recommended way of doing it.
2012/10/20 Agustin Lobo <alobolistas at gmail.com>:
> Great, Ii assume this solves the problem
> Victor,
> Will we have a new version of the Sextante plugin soon or do we have
> to apply the patch ourselves?
> Agus
> On Fri, Oct 19, 2012 at 3:12 PM, Victor Olaya <volayaf at gmail.com> wrote:
>> Thanks!
>> 2012/10/19 rldhont <rldhont at gmail.com>:
>>> Hi Victor,
>>> Ticket opens and patch supplies
>>> http://hub.qgis.org/issues/6545
>>> René-Luc
>>> Le 19/10/2012 10:15, Victor Olaya a écrit :
>>>> That makes sense...
>>>> Please open a ticket and provide a patch, and I will apply it ASAP
>>>> Many thanks!
>>>> Victor
>>>>> Hi all,
>>>>> With a friend of mine, we identifying a bug on Ubuntu with R in sextante.
>>>>> The bug is : The python subprocess doesn't execute the command.
>>>>> The solution put the parameter shell to False on linux for the subprocess
>>>>> Popen construction.
>>>>> Python doc
>>>>> http://docs.python.org/library/subprocess.html#popen-constructor
>>>>> On Windows with shell=True, the COMSPEC environment variable specifies
>>>>> the
>>>>> default shell. The only time you need to specify shell=True on Windows is
>>>>> when the command you wish to execute is built into the shell (e.g. dir or
>>>>> copy). You do not need shell=True to run a batch file or console-based
>>>>> executable.
>>>>> If you want I can open an issue and provide a patch.
>>>>> Regards,
>>>>> René-Luc
>>>>> Le 19/10/2012 10:01, Victor Olaya a écrit :
>>>>>> Agustin
>>>>>> The most useful info here is in the Rlog file that you will find in
>>>>>> [your-user-folder]/sextante
>>>>>> That tells us what was the problem with R (if any). Could you please
>>>>>> send
>>>>>> it?
>>>>>> thanks for your help
>>>>>> Victor
>>>>>> 2012/10/19 Agustin Lobo <alobolistas at gmail.com>:
>>>>>>> I find problem at trying to run R scripts within Sextante
>>>>>>> on ubuntu 10.04 + qgis 1.8
>>>>>>> I include links to screen captures of the results at attempting to run
>>>>>>> the provided example script "Create random sample grid":
>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante1.jpeg
>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante2.jpeg
>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante3.jpeg
>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante4.jpeg
>>>>>>> I've seen a couple or R-Sextante tickets in
>>>>>>> http://hub.qgis.org/projects/sextante/issues
>>>>>>> but I think that they are not related to this, as it seems that
>>>>>>> those users were able to go beyond than I've been. It also seems like R
>>>>>>> Sextante
>>>>>>> might be working on windows and not on linux?
>>>>>>> Should I open a ticket for this in
>>>>>>> http://hub.qgis.org/projects/sextante/issues ?
>>>>>>> Thanks
>>>>>>> Agus
>>>>>>> QGIS version 1.8.0-Lisboa
>>>>>>> QGIS code revision exported
>>>>>>> Compiled against Qt4.6.2
>>>>>>> Running against Qt4.6.2
>>>>>>> Compiled against GDAL/OGR1.9.1
>>>>>>> Running against GDAL/OGR1.9.1
>>>>>>> GEOS Version3.3.3
>>>>>>> PostgreSQL Client Version8.4.12
>>>>>>> SpatiaLite Version2.4.0
>>>>>>> QWT Version5.2.0
>>>>>>> _______________________________________________
>>>>>>> Qgis-developer mailing list
>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
