[Qgis-developer] R Sextante error
Victor Olaya volayaf at gmail.com
Sun Oct 21 12:33:04 PDT 2012
Agustin
Thanks for your help
I will write down how to use the git version so you can have a working
version to test
Once you get your scripts working (the ones you are trying now but do
not work), the best way to help us test things is to write your own
new scripts.
If they work...perfect. If not, we will try to fix them (and hopefully
on time for you meeting).
Thanks again for your help
Victor
> On Sat, Oct 20, 2012 at 9:14 PM, Victor Olaya <volayaf at gmail.com> wrote:
>> Agustin
>> 2 quick things:
>> 1) I am going to prepare a document with instructions to use the
>> latest version from git. That might help you and others as well.
>> 2)If you are doing a presentation about SEXTANTE, that puts you in my
>> list of "privileged" users :-) That means that you can (and you
>> should) ask me for direct help or to prepared a tailored version so
>> you have it ready for your presentation.
>> Anyway, do you have any deadline for that?. I am presenting SEXTANTE
>> at the Russian FOSS4G conference in mid november, and I should have a
>> new version ready by that time. In the meantime, as I said, and if you
>> do not manage to use git, I can send you just a zip file with changes
>> that affect the R engine in SEXTANTE, so you can just unzip them in
>> you QGis plugins folder and test them.
>> Regards
>> Victor
>> 2012/10/20 Agustin Lobo <alobolistas at gmail.com>:
>>> i understand the hassle, but from the point of view of R scripts in
>>> Sextante this is not a bug, it is
>>> that Sextante is totally unusable for this purpose. My intention was
>>> to include this Sextante capability
>>> within my (hopefully) forthcoming presentation on geospatial
>>> capabilities of R in a R users meeting, (and have
>>> been trying using it, see
>>> http://osgeo-org.1560.n6.nabble.com/R-scripts-for-raster-layers-in-External-Apps-of-the-Sextante-Toolbox-plugin-td4998046.html).
>>> I will try the git thing (now that Ii know hot to use svn...), if I
>>> find directions on how to do it.
>>> Agus
>>> On Sat, Oct 20, 2012 at 4:53 PM, Victor Olaya <volayaf at gmail.com> wrote:
>>>> Agustin,
>>>> There are a few importante changes since last version, but I would
>>>> like to close a couple of bugs before releasing a new version. The
>>>> patch, I will apply it today and it will be in the github repo.
>>>> In short, I guess you can count on a new version in less than a month
>>>> (there is not a well defined roadmap at the moment, but that is a good
>>>> estimate). If you want to always have the most recent version (with
>>>> unstable stuff as well...), using the github version is the
>>>> recommended way of doing it.
>>>>> Great, Ii assume this solves the problem
>>>>> Victor,
>>>>> Will we have a new version of the Sextante plugin soon or do we have
>>>>> to apply the patch ourselves?
>>>>> Agus
>>>>> On Fri, Oct 19, 2012 at 3:12 PM, Victor Olaya <volayaf at gmail.com> wrote:
>>>>>> Thanks!
>>>>>> 2012/10/19 rldhont <rldhont at gmail.com>:
>>>>>>> Hi Victor,
>>>>>>> Ticket opens and patch supplies
>>>>>>> http://hub.qgis.org/issues/6545
>>>>>>> René-Luc
>>>>>>> Le 19/10/2012 10:15, Victor Olaya a écrit :
>>>>>>>> That makes sense...
>>>>>>>> Please open a ticket and provide a patch, and I will apply it ASAP
>>>>>>>> Many thanks!
>>>>>>>> Victor
>>>>>>>>> Hi all,
>>>>>>>>> With a friend of mine, we identifying a bug on Ubuntu with R in sextante.
>>>>>>>>> The bug is : The python subprocess doesn't execute the command.
>>>>>>>>> The solution put the parameter shell to False on linux for the subprocess
>>>>>>>>> Popen construction.
>>>>>>>>> Python doc
>>>>>>>>> http://docs.python.org/library/subprocess.html#popen-constructor
>>>>>>>>> On Windows with shell=True, the COMSPEC environment variable specifies
>>>>>>>>> the
>>>>>>>>> default shell. The only time you need to specify shell=True on Windows is
>>>>>>>>> when the command you wish to execute is built into the shell (e.g. dir or
>>>>>>>>> copy). You do not need shell=True to run a batch file or console-based
>>>>>>>>> executable.
>>>>>>>>> If you want I can open an issue and provide a patch.
>>>>>>>>> Regards,
>>>>>>>>> René-Luc
>>>>>>>>> Le 19/10/2012 10:01, Victor Olaya a écrit :
>>>>>>>>>> Agustin
>>>>>>>>>> The most useful info here is in the Rlog file that you will find in
>>>>>>>>>> [your-user-folder]/sextante
>>>>>>>>>> That tells us what was the problem with R (if any). Could you please
>>>>>>>>>> send
>>>>>>>>>> it?
>>>>>>>>>> thanks for your help
>>>>>>>>>> Victor
>>>>>>>>>> 2012/10/19 Agustin Lobo <alobolistas at gmail.com>:
>>>>>>>>>>> I find  problem at trying to run R scripts within Sextante
>>>>>>>>>>> on ubuntu 10.04 + qgis 1.8
>>>>>>>>>>> I include links to screen captures of the results at attempting to run
>>>>>>>>>>> the provided example script "Create random sample grid":
>>>>>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante1.jpeg
>>>>>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante2.jpeg
>>>>>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante3.jpeg
>>>>>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante4.jpeg
>>>>>>>>>>> I've seen a couple or R-Sextante tickets in
>>>>>>>>>>> http://hub.qgis.org/projects/sextante/issues
>>>>>>>>>>> but I think that they are not related to this, as it seems that
>>>>>>>>>>> those users were able to go beyond than I've been. It also seems like R
>>>>>>>>>>> Sextante
>>>>>>>>>>> might be working on windows and not on linux?
>>>>>>>>>>> Should I open a ticket for this in
>>>>>>>>>>> http://hub.qgis.org/projects/sextante/issues ?
>>>>>>>>>>> Thanks
>>>>>>>>>>> Agus
>>>>>>>>>>> QGIS version 1.8.0-Lisboa
>>>>>>>>>>> QGIS code revision exported
>>>>>>>>>>> Compiled against Qt4.6.2
>>>>>>>>>>> Running against Qt4.6.2
>>>>>>>>>>> Compiled against GDAL/OGR1.9.1
>>>>>>>>>>> Running against GDAL/OGR1.9.1
>>>>>>>>>>> GEOS Version3.3.3
>>>>>>>>>>> PostgreSQL Client Version8.4.12
>>>>>>>>>>> SpatiaLite Version2.4.0
>>>>>>>>>>> QWT Version5.2.0
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> Qgis-developer mailing list
>>>>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
