[Qgis-developer] Invert color ramp not working?
Paolo Cavallini
cavallini at faunalia.it
Wed Oct 24 15:59:28 PDT 2012
Il 25/10/2012 02:52, Radim Blazek ha scritto:
> You are probably expecting the classification to be done in reverse order?
Yes.
> I think that invert color has little/no sense for pseudocolor and
> multiband color as it is implemented in master or/and was in 1.8. For
> pseudo color it should be moved to "Generate new color map" options,
> for multiband color just removed.
seems good. can we disable the invert for multibands?
> In any case, legend is not correct if invert color is used.
I believe this should be fixed anyway.
Thanks a lot.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
