[Qgis-developer] again on encoding problems
Paolo Cavallini
cavallini at faunalia.it
Wed Oct 24 23:16:38 PDT 2012
Thanks maris.
Are grass dev aware of the problem? Could we then display grass in English when on windows, for these languages?
It seems important.
All the best.
Maris Nartiss <maris.gis at gmail.com> ha scritto:
>Hello Paolo,
>I haven't seen how QGIS GRASS plug in is built, still my 0.02 from
>GRASS side. Some time a go I investigated encoding problems in native
>GRASS on Windows (WinGRASS) and my conclusion was - it is not possible
>to fix it for GRASS 6 due to character encoding handling in Windows.
>Reason was simple - there's no single coding to cover all use cases in
>Windows (CLI has one system (OEM), GUI has it's legacy system (ANSI)
>and add to all also Unicode in more recent code). As GRASS strings
>might come in all three encodings, unless the source of string is
>known, it's impossible to convert/display string correctly.
>Somebody with greater QGIS part can correct me, if I'm wrong (as I
>would like to be :) ).
>Maris.
>PS. http://lists.osgeo.org/pipermail/grass-dev/2011-March/053874.html
>2012/10/24 Paolo Cavallini <cavallini at faunalia.it>:
>> Hi all.
>> Here in the Far East the encoding is a serious problem hampering the
>use
>> of QGIS.
>> I was just pointed out a problem with the GRASS plugin on Win:
>> http://hub.qgis.org/issues/4547
>> and the solution the use:
>http://osgeo-org.1560.n6.nabble.com/Qgis1-5-Grass-tt3730164.html#a3730165
>> basically they set up the entire environment in EN, but this is not
>> optimal, as the translation is actually there, as we can see e.g. on
>osx
>> and of course on Linux.
>> It looks a very simple problem, anybody has an idea on how to solve
>it
>> more elegantly?
>> All the best, and thanks.
>> Paolo Cavallini - Faunalia
>> www.faunalia.eu
>> Full contact details at www.faunalia.eu/pc
>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
http://faunalia.it/pc
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121025/66587d64/attachment.html>
