[Qgis-developer] QGIS infrastructure mindmap
Pirmin Kalberer pi_ml at sourcepole.com
Mon Oct 29 01:11:05 PDT 2012
Hi Andreas,
Am Montag, 29. Oktober 2012, 17.33:04 schrieb Nathan Woodrow:
> That is looking really good.  Nice to see where things are in relation
> to everything else.  Might be good to have the different build servers
> and some notes about who maintains them and their specs.
The Linux builds are done in the www.(plugins/plant/hub).qgis.org VM (It's a
single VM!). The Windows nightly builds are done on a internal machine of jef,
AFAIK.
I would conctentrate on the technical dependencies of the QGIS infrastructure
and therefore remove the Commercial support componies, etc.
Pirmin
> On Mon, Oct 29, 2012 at 5:19 PM, Andreas Neumann <a.neumann at carto.net>
wrote:
> > Hi Paolo,
> > You can mouse over the little icons to the left of the text to see the
> > comments and the links.
> > If you want to edit I need to register you as an editor (in the sharing
> > settings).
> > Andreas
> > On Mon, 29 Oct 2012 07:57:41 +0900, Paolo Cavallini wrote:
> >> Il 29/10/2012 02:44, Andreas Neumann ha scritto:
> >>> Hi,
> >>> At the HF in Essen I promised to create a mindmap representing the quite
> >>> distributed infrastructure. Here it is:
> >>> http://app.wisemapping.com/c/maps/81444/public
> >> thanks Andreas!
> >>> I tried to add URLs and comments with a short explanation and the
> >>> responsible administrators.
> >> I can't see that, possible?
> >> All the best.
> > Andreas Neumann
> > Böschacherstrasse 10A
> > 8624 Grüt (Gossau ZH)
> > Switzerland
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Pirmin Kalberer
Sourcepole  -  Linux & Open Source Solutions
http://www.sourcepole.com
