[Qgis-developer] QGIS infrastructure mindmap
Tim Sutton
lists at linfiniti.com
Mon Oct 29 03:00:03 PDT 2012
Hi
On Mon, Oct 29, 2012 at 10:39 AM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Pirmin,
> I removed the commercial support and QGIS associations and added the build
> servers.
> I added Paolo and you in the sharing settings so you can correct and edit
> the mind map. You should have received a separate email with the link.
> Andreas
Very nice! Oh you can add the android build server is on linfiniti's server
Is the mind map downloadable in a re-usable form? Might be nice to get
it as a graphviz file or similar.
Regards
Tim
> On Mon, 29 Oct 2012 09:11:05 +0100, Pirmin Kalberer wrote:
>> Hi Andreas,
>> Am Montag, 29. Oktober 2012, 17.33:04 schrieb Nathan Woodrow:
>>> That is looking really good. Nice to see where things are in relation
>>> to everything else. Might be good to have the different build servers
>>> and some notes about who maintains them and their specs.
>> The Linux builds are done in the www.(plugins/plant/hub).qgis.org VM (It's
>> a
>> single VM!). The Windows nightly builds are done on a internal
>> machine of jef,
>> AFAIK.
>> I would conctentrate on the technical dependencies of the QGIS
>> infrastructure
>> and therefore remove the Commercial support componies, etc.
>> Pirmin
>>> On Mon, Oct 29, 2012 at 5:19 PM, Andreas Neumann <a.neumann at carto.net>
>> wrote:
>>> > Hi Paolo,
>>> > You can mouse over the little icons to the left of the text to see the
>>> > comments and the links.
>>> > If you want to edit I need to register you as an editor (in the sharing
>>> > settings).
>>> > Andreas
>>> > On Mon, 29 Oct 2012 07:57:41 +0900, Paolo Cavallini wrote:
>>> >> Il 29/10/2012 02:44, Andreas Neumann ha scritto:
>>> >>> Hi,
>>> >>> At the HF in Essen I promised to create a mindmap representing the
>>> >>> quite
>>> >>> distributed infrastructure. Here it is:
>>> >>> http://app.wisemapping.com/c/maps/81444/public
>>> >> thanks Andreas!
>>> >>> I tried to add URLs and comments with a short explanation and the
>>> >>> responsible administrators.
>>> >> I can't see that, possible?
>>> >> All the best.
>>> > Andreas Neumann
>>> > Böschacherstrasse 10A
>>> > 8624 Grüt (Gossau ZH)
>>> > Switzerland
>>> > _______________________________________________
>>> > Qgis-developer mailing list
>>> > Qgis-developer at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Andreas Neumann
> Switzerland
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
