[Qgis-developer] html goodness in Map Composer
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Sep 3 22:59:10 PDT 2012
Hi Maning
There is already a html item in the map composer of the dev version
(also using webkit). You may select 'add html item' and drag a
rectangle. Then you can select an html file or a web resource (it is
even possible to display a web page on the composer). The item can have
several frames and thus go over multiple pages.
Regards,
Marco
On 04.09.2012 06:31, maning sambale wrote:
> I just read the recent features of QGIS master from Nathan's blog [0].
> The HTML annotatons is ubercool.
> Are there plans to integrate html tags and css to the Map Composer?
> [0] http://woostuff.wordpress.com/2012/09/04/five-new-awesomely-awesome-qgis-features/
