[Qgis-developer] Better options dialogs
Larry Shaffer
larrys at dakotacarto.com
Wed Sep 5 12:47:57 PDT 2012
Hi Marco,
On Wed, Sep 5, 2012 at 1:26 PM, Marco Bernasocchi
<marco at bernawebdesign.ch> wrote:
> On 09/06/2012 02:10 AM, Larry Shaffer wrote:
>> Hi,
> Hi Larry,
> Looks great to me, but not the version without text, too hard to guess,
The version with only icons is optional, and is produced by setting an
appropriate minimum width for the list widget. If a user wanted to
size it that way, it is possible (and a saveable window state), but I
am definitely not in favor of it being a default. Thanks for the
input!
Larry
> so +1 for me foremost for freeing vertical space
> ciao
> MArco
>> I've been working on reducing overall clutter and excess space, and
>> trying to increase efficiency and extensibility, with options dialogs.
>> Problems with current option dialogs' parent QTabWidget approach:
>> * Tab widget uses unnecessary vertical space (bad for small screens).
>> * Tab widget limits the use of reasonably needed tabs for option
>> sections (avoiding tabs-within-tabs unfortunately trumps useability).
>> * Horizontal parent tabs limit how many option sections can be offered
>> (already too wide, without text truncation, on Mac).
>> * Horizontal parent tabs dictate the width of the dialog, causing form
>> layout elements to optically stretch too far apart.
>> Possible solution: Move 'tabs' to simple list widget on left side of a
>> splitter and have option sections loaded on right.
>> I have done mockups for the app and vector layer options [0], which
>> show the following advantages:
>> * Vertical height is maximized without sacrificing layout of option
>> section form elements (good for smaller screens).
>> * Number of option sections is not graphically limited.
>> * Number of option sections no longer dictates width of option section
>> forms (forms look much better).
>> * List item widget can have its splitter section collapsed to a set
>> size to show only icons for sections.
>> * Consistent look across platforms, with larger icons for sections.
>> * More current 'look' for v 2.0 without too much work.
>> Other than making the dialogs clearer and less cluttered IMHO, the
>> full useability of the dialogs at smaller sizes helps the user see
>> more map canvas when testing options with Apply.
>> Any comments or suggestions?
>> [0] https://www.dropbox.com/sh/yy0j3mmg4l4kw7x/Ar_S-eYqCv/qgis/options-dlgs?lst
>> Regards,
>> Larry
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Marco Bernasocchi
> http://opengis.ch
