[Qgis-developer] Better options dialogs
    Alexander Bruy
    alexander.bruy at gmail.com
    Thu Sep  6 00:02:51 PDT 2012
Hi Larry,
as already was mentioned in this thread similar design of options dialog
was used several versions ago but then we switched to tabs. List widget
only with icons IMHO not user friendly, especially for newcomers.
If icons will be with captions we again come to initial problem for translators:
translating some text when listbox is used is a real pain in some languages.
I think Jean-Roc Morreale can explain all problems for translators better.
2012/9/5 Larry Shaffer <larrys at dakotacarto.com>:
> Possible solution: Move 'tabs' to simple list widget on left side of a
> splitter and have option sections loaded on right.
> I have done mockups for the app and vector layer options [0], which
> show the following advantages:
Alexander Bruy
