[Qgis-developer] Object owner design in QgsGraphBuilder
Kuhn Matthias, Vermessung
Matthias.Kuhn at Stadt-Uster.ch
Thu Sep 6 00:14:25 PDT 2012
> > Was your idea to put such information into the properties
> > QVector that can be passed with addArc()? Would it be
> > feasible to integrate this also for vertices in one way or another?
> The idea is that you should not edit QgsGraph object :-) .
> Probably I will not add the properties top. New functional is
> not a big problem for me, but I do not know why it.
My problem is the following: I have a layer containing the nodes and another layer (actually even a combination of two layers) containing the edges. They are connected by data definition and not only/necessarily geometry. Each node has some properties which are saved as attributes in the node layer.
If I can store a reference (feature id) to the node in the vertex on the graph I can access all these properties when iterating over a found shortest path. This can be useful e.g. if you want to draw a height profile of this path.
> If you create an object without using QgsGraph
> QgsGraphBuilder QgsGraphDirector then a good idea to use
> other libraries to analyze graphs. For example, bgl [1] or
> NetworkX [2]. And I use the builder pattern [3], so you can
> use the algorithm analyzes the vector layer
> (QgsLineVectorGraphDirector object). I spent a lot of time debugging.
I like to minimize dependencies and your library already fits my purpose pretty well :)
I can stick to the builder pattern and write my own Director / Builder for this.
But I can only do this, if I am able to store at least one additional reference in QgsGraphVertex.
Cheers
> Currently I work of full-feature network and surface cost
> analysis plugin, but I will not use more than the shortest
> path and minimum spanning tree.
> Thanks.
> [1] http://www.boost.org/doc/libs/1_51_0/libs/graph/doc/index.html
> [2] http://networkx.lanl.gov/
> [3] http://en.wikipedia.org/wiki/Builder_pattern
> Sergey Yakushev
> Qgis-developer mailing list
