[Qgis-developer] Better options dialogs
Alexander Bruy
alexander.bruy at gmail.com
Thu Sep 6 03:32:31 PDT 2012
Hi Larry,
2012/9/6 Larry Shaffer <larrys at dakotacarto.com>:
> Thanks for the input. Might you be referring to
> http://hub.qgis.org/issues/2202 ?
Right, this is one of the problems. Not sure if there were others.
> My proposed layout does not have that issue. The one for 1.6 used
> large icons with text that was center-justified and wrapped
> underneath, but had no means of increasing the overall width of the
> widget by the user. It appears the larger icons were to aid in that
> problem, but weren't enough for longer translations.
Great, then looking forward for this new desing in QGIS. Thanks for
your work!
Alexander Bruy
