[Qgis-developer] [QGIS Commit] [qgis/Quantum-GIS] d77973: Revert "Fix from lynxlynxlynxlynxlynx for building...
Tim Sutton lists at linfiniti.com
Fri Sep 7 03:45:48 PDT 2012
Hi
On Fri, Sep 7, 2012 at 12:00 PM, 欧阳乐岩 <ouyang.leyan at hotmail.com> wrote:
> I am unable to compile the latest QGis, I guess this is the same issue? (I
> am using ArchLinux)
> [ 47%] Built target qgis.d.rast
> Linking C executable ../../../output/lib/qgis/grass/modules/qgis.g.info
> /usr/bin/ld: CMakeFiles/qgis.g.info.dir/qgis.g.info.c.o: undefined reference
> to symbol 'pow@@GLIBC_2.0'
> /usr/bin/ld: note: 'pow@@GLIBC_2.0' is defined in DSO /usr/lib/libm.so.6 so
> try adding it to the linker command line
> /usr/lib/libm.so.6: could not read symbols: Invalid operation
Jaka Kranjc just resubmitted a platform specific patch - please pull
and try again.
Regards
Tim
> On 09/07/2012 04:08 PM, Tim Sutton wrote:
>> Hi
>> On Thu, Sep 6, 2012 at 4:33 PM, William Kyngesburye
>> <woklist at kyngchaos.com> wrote:
>>> Tim, do you know what problem this was meant to fix?
>> It seems to be an edge case where lynxlynxlynx has a grass install
>> that is not linked to libm
>> 14:05:32        lynxlynxlynx:   it's not osx, i'm on linux
>> 14:05:38        timlinux:       lynxlynxlynx: oh
>> 14:05:51        timlinux:       I wonder why only you had that compile
>> issue
>> 14:06:12        lynxlynxlynx:   probably my grass doesn't have -lm stored
>> in its pc file
>> 14:07:17        timlinux:       lynxlynxlynx: I will revert it for now
>> 14:08:08        lynxlynxlynx:   wrap it in a windows check
>> 14:09:05        lynxlynxlynx:   or msvc specifically, if mingw is
>> supported
>> 14:09:07        GitHub59:       [Quantum-GIS] timlinux pushed 2 new
>> commits to
>> master: http://git.io/wdmTfQ
>> 14:09:07        GitHub59:       [Quantum-GIS/master] Revert "Fix from
>> lynxlynxlynxlynxlynx for building grass on mac" - Tim Sutton
>> Regards
>> Tim
>>> On Sep 6, 2012, at 9:01 AM, GitHub wrote:
>>>>   Branch: refs/heads/master
>>>>   Home:   https://github.com/qgis/Quantum-GIS
>>>>   Commit: d77973d0d3a126190656b9297c724c680a67d38b
>>>> https://github.com/qgis/Quantum-GIS/commit/d77973d0d3a126190656b9297c724c680a67d38b
>>>>   Author: Tim Sutton <tim at linfiniti.com>
>>>>   Date:   2012-09-06 (Thu, 06 Sep 2012)
>>>>   Changed paths:
>>>>     M src/providers/grass/CMakeLists.txt
>>>>   Log Message:
>>>>   Revert "Fix from lynxlynxlynxlynxlynx for building grass on mac"
>>>> This reverts commit 977518af3a669aac1045eebb5b00fce2b6d50680.
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> Theory of the Universe
>>> There is a theory which states that if ever anyone discovers exactly what
>>> the universe is for and why it is here, it will instantly disappear and be
>>> replaced by something even more bizarrely inexplicable.  There is another
>>> theory which states that this has already happened.
>>> -Hitchhiker's Guide to the Galaxy 2nd season intro
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
