[Qgis-developer] ohloh stats
Sandro Santilli
strk at keybit.net
Wed Sep 12 08:19:37 PDT 2012
On Wed, Sep 12, 2012 at 05:16:42PM +0200, Paolo Cavallini wrote:
> Il 12/09/2012 17:14, Sandro Santilli ha scritto:
> > It may help if you see a specific commit which is missing.
> > I assumed we only miss 1,2 and 3 because git history starts
> > with SVN revision 4, but there might be more "holes" due to
> > commits in different SVN branches not represented in git.
> if I enable only the git repo, the history starts from the time when we switched to
> git, nothing from svn.
In that case I bet it's the ohloh counter only fetching commits
which are _newer_ than what it already has. If that's the case
things _may_ fix by removing the git repo link and then re-adding
it, but only if the ohloh service drops the whole cache as soon as
you drop the repository. Better to wait for ohloh devs response.
--strk;
