[Qgis-developer] Migration of SEXTANTE repository
Tim Sutton
lists at linfiniti.com
Sun Sep 16 13:13:31 PDT 2012
Hi
On Sat, Sep 15, 2012 at 10:10 AM, Filipe Dias <filipesdias at gmail.com> wrote:
> Hi,
> Some of us (regular Sextante testers) were using Tortoise svn (Windows) to
> download the latest code revision of Sextante. As soon as Victor Olaya
> solved one of the bugs we reported, we would download the lastest revision
> of Sextante and check if everything was ok.
> Is there another program we can use to the same in the new repository? I
> tried using Tortoise but it didnt work.
> I think this dynamic contributed a lot to the fast paced development of
> Sextante in QGIS and kept a lot of people interested. I fear that this 24
> hour (or more) delay will break some of the momentum Sextante has had.
> Thanks
> Regards
Yes if you refer back to hte original discussion of moving SEXTANTE to
QGIS core, you will see that I mentioned we can set up an automated
export of the SEXTANTE plugin. We just need to determine the rules
about how and when such exports should be made.
Regards
Tim
> On Fri, Sep 14, 2012 at 10:52 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> On Fri, Sep 14, 2012 at 11:12 PM, skampus
>> <stefano.campus at regione.piemonte.it> wrote:
>> > does it mean that every change in sextante will be added into qgis
>> > master
>> > every time it is released
>> > (almost every night)?
>> That depends on how the SEXTANTE team chooses to work. Normally new
>> development work should be donw in individual developers repos and
>> then pushed over to the QGIS master repo when they are ready for
>> general consumption. But fixes and small changes can indeed be pushed
>> over on a nightly basis.
>> > and if it's, so, is not necessary to update sextante via svn
>> > anymore,isn't
>> > it?
>> Yes the SVN repo should not be used anymore as there is no longer any
>> intention to move changes from svn to the QGIS repo.
>> Regards
>> Tim
>> > sorry for trivial question
>> > s.
>> > View this message in context:
>> > http://osgeo-org.1560.n6.nabble.com/Migration-of-SEXTANTE-repository-tp4992397p5002021.html
>> > Sent from the Quantum GIS - Developer mailing list archive at
>> > Nabble.com.
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>> * QGIS programming and support services
>> * Mapserver and PostGIS based hosting plans
>> * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
Skype: timlinux
