[Qgis-developer] Map production using Python
Pedro Camargo
veigacamargo at gmail.com
Tue Sep 18 16:05:00 PDT 2012
Hi guys,
I have a few questions that I'd like to ask here.
1st - I'm trying to write a code that I can run from a python shell
outside QGIS, but I'm not finding the path where I should be importing qgis
from.
2nd - I have to print a series of hundreds of maps and I was
planning into using the a map composer, but in the map I get, my layer
occupy a small part of the whole composer. I have this problem when I'm
working manually too, but then I can correct it. How can I set it right so
my layer take the whole canvas?
I'm using the following software:
- Windows 7 64bits
- QGIS 1.8
Python 2.73
Thanks,
Pedro
-----Original Message-----
[mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of
qgis-developer-request at lists.osgeo.org
Sent: Tuesday, September 18, 2012 12:00 PM
To: qgis-developer at lists.osgeo.org
Subject: Qgis-developer Digest, Vol 83, Issue 49
Send Qgis-developer mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/qgis-developer
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-developer-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Qgis-developer digest..."
Today's Topics:
1. Re: [Qgis-user] Sextante - error saving a model with Select
by location tool (Victor Olaya)
2. Re: Demo WMS/WFS QGIS server (Tim Sutton)
3. Re: Add ST_MakeValid functionality to QgsGeometry?
(Giovanni Manghi)
4. Re: [Qgis-user] Sextante - error saving a model with Select
by location tool (Pedro Ven?ncio)
5. Re: Demo WMS/WFS QGIS server (Paolo Cavallini)
6. Re: Demo WMS/WFS QGIS server (Tim Sutton)
7. QgsFillSymbolLayerV2 descendants missing from sip (Massimo)
8. PyCookBook wrong link (Paolo Cavallini)
Message: 1
Date: Tue, 18 Sep 2012 13:23:26 +0200
To: Pedro Ven?ncio <pedrongvenancio at yahoo.com>
Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>, Qgis
Developer List <qgis-developer at lists.osgeo.org>
Subject: Re: [Qgis-developer] [Qgis-user] Sextante - error saving a
model with Select by location tool
Message-ID:
<CAJsc-7ytbdCPXW9fniSMsUfB1CEUA0e65JgKjjX6TqhdqyqR3g at mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
Yes please, fill a ticket.
Many thanks!
2012/9/18 Pedro Ven?ncio <pedrongvenancio at yahoo.com>:
> Hi Victor,
> Ok, thanks!
> I also found a problem with the Select tool from MMQGISX. When selecting a
physical layer that is loaded in QGIS, even in modeler, it works well.
However, when using Select with intermediate layers within modeler, it says
that the project has no active layer to select from (image attached).
> I think I'll fill a ticket for both problems, what do you think?
> Thank you very much!
> Best regars,
> Pedro
> PS: Good luck with your new job! :)
> ----- Original Message -----
> From: Victor Olaya
> Hi Pedro
> The problem is that the select algorithm does not generate a new
> layer, but just makes a selection on a existing one. It seems that
> this case hasn't been correctly considered...
> I will have a look at it and see if I can fix it
> Regards
>> Hi,
>> I can not save a model in which is used the tool 'Select by location'
from fTools.
>> When saving, it shows the error:
>> An error has occured while executing Python code:
>> Traceback (most recent call last):
>> File
"/home/pedro/.qgis//python/plugins/sextante/modeler/ModelerDialog.py", line
219, in saveModel
>> text = self.alg.serialize()
>> File
"/home/pedro/.qgis//python/plugins/sextante/modeler/ModelerAlgorithm.py",
line 305, in serialize
>> s+=unicode(self.algOutputs[i][out.name]) + "\n"
>> KeyError: 'OUTPUT'
>> Python version:
>> 2.7.3 (default, Aug 1 2012, 05:27:35) [GCC 4.6.3]
>> QGIS version:
>> 1.9.0-Master Master, exported
>> Python path: ['/home/pedro/.qgis//python/plugins/ogrprocessing',
>> '/home/pedro/.qgis//python/plugins/sextante',
>> '/usr/share/qgis/python', '/home/pedro/.qgis//python',
>> '/home/pedro/.qgis//python/plugins',
>> '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
>> '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk',
>> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
>> '/usr/local/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages/PIL',
>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>> '/usr/lib/python2.7/dist-packages/gtk-2.0',
>> '/usr/lib/pymodules/python2.7',
>> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
>> '/home/pedro/.qgis/python/plugins/mmqgis/forms',
>> '/home/pedro/.qgis/python/plugins/qgis2kml',
>> '/usr/share/qgis/python/plugins/fTools/tools']
>> And then, when I try to remove the module 'Select by location' from the
model, it shows the error:
>> File
"/home/pedro/.qgis//python/plugins/sextante/modeler/ModelerGraphicItem.py",
line 89, in removeElement
>> if not self.model.removeAlgorithm(self.elementIndex):
>> File
line 164, in removeAlgorithm
>> val = self.algOutputs[index][out.name]
>> KeyError: 'OUTPUT'
>> Python version:
>> Which will be the problem?
>> Best regards,
>> Pedro Ven?ncio
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Message: 2
Date: Tue, 18 Sep 2012 13:52:57 +0200
To: Paolo Cavallini <cavallini at faunalia.it>
Cc: qgis-developer <qgis-developer at lists.osgeo.org>
Subject: Re: [Qgis-developer] Demo WMS/WFS QGIS server
Message-ID:
<CALCNqkZ6V8_bjyu5O1d5+bCc0Dt+VbaLoNhS-_Yz_VTqy4T3YA at mail.gmail.com>
Hi
On Tue, Sep 18, 2012 at 12:37 PM, Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Hi all.
> Would it be reasonable having a sample WMS and WFS QGIS instance,
> automatically installed at every commit?
> I think it would be useful to quickly spot issues with various clients
etc.
I could do this with jenkins....maybe remind me at the HF if I dont get to
it before then.
Regards
Tim
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc Nuovi corsi QGIS e PostGIS:
> http://www.faunalia.it/calendario
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical support questions. Using the
lists will gain more exposure for your issues and the knowledge surrounding
your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
Message: 3
Date: Tue, 18 Sep 2012 13:06:15 +0100
From: Giovanni Manghi <giovanni.manghi at faunalia.pt>
Subject: Re: [Qgis-developer] Add ST_MakeValid functionality to
QgsGeometry?
Message-ID: <1347969975.2633.115.camel at sibirica>
Content-Type: text/plain; charset="UTF-8"
Hi Larry,
> What's the likelihood that the ST_MakeValid function could be ported
> to QGIS?... ending up with something like:
glad you raised this question. The common users really misses a tool to
allow easily fix geometries in QGIS, and the feedback is that when is needed
they usually use other GIS software (for example many of the tools in the
"vector" menu do not return the expected results if the geometries are not
valid).
Any improvement in this field would be very welcome.
cheers
-- Giovanni --
Message: 4
Date: Tue, 18 Sep 2012 06:22:23 -0700 (PDT)
From: Pedro Ven?ncio <pedrongvenancio at yahoo.com>
To: Victor Olaya <volayaf at gmail.com>
Message-ID:
<1347974543.91931.YahooMailNeo at web122303.mail.ne1.yahoo.com>
Content-Type: text/plain; charset=iso-8859-1
Ok Victor, just for record on this thread:
http://hub.qgis.org/issues/6362
http://hub.qgis.org/issues/6363
Thanks!
Best regards,
Pedro
Many thanks!
Message: 5
Date: Tue, 18 Sep 2012 16:54:35 +0200
To: Tim Sutton <lists at linfiniti.com>
Message-ID: <50588B2B.80209 at faunalia.it>
> get to it before then.
I took the liberty of adding it here, hope you do not mind:
http://hub.qgis.org/wiki/quantum-gis/8_QGIS_Developer_Meeting_in_Essen_2012#
Participation
thanks
www.faunalia.eu
Message: 6
Date: Tue, 18 Sep 2012 16:59:57 +0200
Message-ID:
<CALCNqkaWwqbOTOGTTqwKhhTA9jrB28jPVe_qUzdbrDZ9u24VFg at mail.gmail.com>
Hi
On Tue, Sep 18, 2012 at 4:54 PM, Paolo Cavallini <cavallini at faunalia.it>
Participation
> thanks
Perfect!
T
> www.faunalia.eu
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
support questions. Using the lists will gain
surrounding your issue will be shared with all.
Skype: timlinux
Message: 7
Date: Tue, 18 Sep 2012 09:52:54 -0700 (PDT)
Subject: [Qgis-developer] QgsFillSymbolLayerV2 descendants missing
from sip
Message-ID: <1347987174862-5002739.post at n6.nabble.com>
Content-Type: text/plain; charset=us-ascii
Dear QGis developper Team,
QgsFillSymbolLayerV2 descendants, but also QgsLineSymbolLayerV2 and
QgsMarkerSymbolLayerV2 descendants are missing from sip.
Working with styles to a deep level it is impossible without such
exportation.
Is this by design or can I add all the missing stuff in sip files?
Regards
Massimo
View this message in context:
http://osgeo-org.1560.n6.nabble.com/QgsFillSymbolLayerV2-descendants-missing
-from-sip-tp5002739.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
Message: 8
Date: Tue, 18 Sep 2012 19:17:26 +0200
To: qgis-developer <qgis-developer at lists.osgeo.org>
Subject: [Qgis-developer] PyCookBook wrong link
Message-ID: <5058ACA6.3090303 at faunalia.it>
Content-Type: text/plain; charset=ISO-8859-15
http://www.qgis.org/pyqgis-cookbook/intro.html
the link complete QGIS API
is pointing to
http://doc.qgis.org/
instead of
http://qgis.org/api/
All the best.
www.faunalia.eu
End of Qgis-developer Digest, Vol 83, Issue 49
