[Qgis-developer] Map production using Python
    Tim Sutton
    lists at linfiniti.com
    Wed Sep 19 13:25:04 PDT 2012
Hi
On Wed, Sep 19, 2012 at 3:12 AM, leyan ouyang <ouyang.leyan at hotmail.com> wrote:
> Regarding the second question, if I remember correctly, you can use
> setNewExtent on your ComposerMap object (taking a QgsRectangle as argument).
>> From: veigacamargo at gmail.com
>> To: qgis-developer at lists.osgeo.org
>> Date: Tue, 18 Sep 2012 16:05:00 -0700
>> Subject: [Qgis-developer] Map production using Python
>> Hi guys,
>> I have a few questions that I'd like to ask here.
>> 1st - I'm trying to write a code that I can run from a python shell
>> outside QGIS, but I'm not finding the path where I should be importing
>> qgis
>> from.
I have documented the process fairly well here:
http://inasafe.org/developer-docs/platform_windows.html#command-line-environment-setup
8<-----------------snip----------------------------------
Please take the trouble to snip away other messages from your email if
you are in digest mode as it improves the signal to noise ratio.
Thanks!
Regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
