[Qgis-developer] Problem with intersects function on windows only
Nic
kempnj at gmail.com
Thu Sep 20 04:06:01 PDT 2012
Hi
I have the same issue using Windows 7.
I've changed the code the intersection with pointBuff instead of pntGeom:
if feat.geometry().intersects(pntBuff).
It returns a result but the only problem is that it will select every
feature within the:
pntGeom.buffer( (self.canvas.mapUnitsPerPixel() * 2),0). This can create
problems if the user is zoomed out too far. So there must be a better way of
solving the Problem.
The feat.geometry().intersects(pntGeom) also works for Polygons. So I don't
think it's the intersect function that returns no geometry.
Kind regards
bertGIS wrote
> Hello,
> I use this code for selecting features, for selecting a feature and get
> its parameters in a form.
> It works well on Ubuntu, but when moving to Windows 7 with QGIS 1.7.4 or
> QGIS 1.8,
> the selection does not work, seems to be the intersect function that
> Does anybody knows something about that ?
> Thanks for your help
> Cheers,
> Bert
> def selectFeature(self, point, button):
> self.selectList = []
> QMessageBox.information( self.iface.mainWindow(),"Info", "in
> selectFeature function" )
> pntGeom = QgsGeometry.fromPoint(point)
> pntBuff = pntGeom.buffer( (self.canvas.mapUnitsPerPixel() * 2),0)
> rect = pntBuff.boundingBox()
> if self.cLayer:
> feat = QgsFeature()
> self.provider.select([],rect)
> while self.provider.nextFeature(feat):
> QMessageBox.information( self.iface.mainWindow(),"Info", "loop on
> features" )
> if feat.geometry().intersects(pntGeom):
> "feature" + str(feat.id()) + " inter")
> self.selectList.append(feat.id())
> if self.selectList:
> self.cLayer.setSelectedFeatures(self.selectList)
> self.updateForm()
> else:
> QMessageBox.information( self.iface.mainWindow(),"Info", "No layer
> currently selected in TOC" )
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-with-intersects-function-on-windows-only-tp4998864p5003200.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
