[Qgis-developer] Access to buffered? point coordinates
Nathan Woodrow
madmanwoo at gmail.com
Thu Sep 20 14:38:20 PDT 2012
If you can run the latest dev version I have changed it so that the
method is passes the full feature rather then just the id.
So the method is: def mymethod(dialog, layer, feature).
In 1.8 there is no way to do want you need.
Sent from some fancy phone looking thingo
Sent: 21/09/2012 12:25 AM
To: qgis-developer at lists.osgeo.org
Subject: [Qgis-developer] Access to buffered? point coordinates
Hello,
I'm working on a customized user interface (based on PyQt) for attribute
data input while digitizing single points. I know about the interface
provided by QGIS for capturing these data (i. e. using widgets with the
same name as the associated attribute), but I would prefer to do the
processing/storing by myself. In this context I need to retrieve
programmatically the geometry/coordinates of a newly digitized point
before the form window ist closed. Can anybody give me a hint how to do
this? I have already tried to use the last cursor position in some way
but didn't succeed.
Thank you in advance for your help!
Stephan Breisig
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
