[Qgis-developer] index in self.legend.groupLayerRelationship - different behavior between QGIS 1.8 and master?
Massimo massimo.endrighi at geopartner.it
Tue Sep 25 23:30:59 PDT 2012
if you are going to review legend management please keep in mind that it
would be very usefull to:
- insert/move a layer into a sub group and not only in a top level group
- move a layer in a cerain position, before or after a specified layer
- read/extract the exact legend hierarchy
In this way it is possible to create a layer/group hierarchy starting from
an external source and vice versa.
I will be happy to contribute to such a work as I partially did with a
previous pull request https://github.com/qgis/Quantum-GIS/pull/217
Regards
Massimo
View this message in context: http://osgeo-org.1560.n6.nabble.com/index-in-self-legend-groupLayerRelationship-different-behavior-between-QGIS-1-8-and-master-tp5004337p5004488.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
