[Qgis-developer] [Qgis-user] Using/visualizing 3D data (Z values)
Nathan Woodrow
madmanwoo at gmail.com
Wed Sep 26 06:38:35 PDT 2012
That's cool. It would be cool if there was a QGIS plugin that took
the selected features and rendered them in 3D using matplotlib.... :)
- Nathan
On Wed, Sep 26, 2012 at 11:26 PM, gene <martin.laloux at gmail.com> wrote:
> Using a script like:
> def select_all(couche):
> couche.select([])
> couche.setSelectedFeatures([obj.id() for obj in couche])
> macouche = qgis.utils.iface.activeLayer()
> select_all(macouche)
> from shapely.wkb import loads
> from shapely.geometry import shape
> lignes = []
> for elem in macouche.selectedFeatures():
> geom= elem.geometry()
> wkb = geom.asWkb()
> lignes.append(loads(wkb))
> list(lignes.coords)
> You have all the elements (x,y and z) to plot your geometry in 3D with
> matplotlib, visvis or others or to use the Python grass.script module to
> create a 3D layer in GRASS
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Re-Qgis-user-Using-visualizing-3D-data-Z-values-tp5004272p5004652.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
