[Qgis-developer] Tickets for plugins
Agustin Lobo
alobolistas at gmail.com
Fri Sep 28 11:36:13 PDT 2012
I was trying here:
http://hub.qgis.org/projects/qgis-user-plugins/issues
Reported now. Thanks
Agus
On Fri, Sep 28, 2012 at 8:16 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> On 09/28/2012 10:28 AM, Agustin Lobo wrote:
>> I've tried to add a ticket for plugin "Add Pin" and get
>> "No tracker is associated to this project. Please check the Project settings."
>> if I have User plugins selected on the upper right corner
>> How do I open a ticket for this plugin that does not work (the point
>> is not drawn)
>> in 1.8. for linux? (works on mac and works with 1.7.4 on linux)
>> Agus
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Are you talking about the PinPoint plugin?
> http://hub.qgis.org/projects/pinpoint
> Were you logged in? Once logged in do you see a New Issue menu item?
> It does appear to have a tracker but I might need to check the
> permissions on who can add Issues.
> Thanks,
> Alex
