[Qgis-developer] Tickets for plugins
Alex Mandel
tech_dev at wildintellect.com
Fri Sep 28 12:14:48 PDT 2012
I see the problem,
http://hub.qgis.org/projects/qgis-user-plugins/issues/new doesn't exist,
you have to go the the sub-project for the specific plugin in order to
file a bug. In this case http://hub.qgis.org/projects/pinpoint is the
correct place to the file the bug in question.
The Issues link is valid though because it summarizes all sub-projects.
So I think I need to find a way to hide the New Issues for that
particular parent project.
Thanks,
Alex
On 09/28/2012 12:00 PM, Etienne Tourigny wrote:
> When I login I can create new issues there (but I have dev permissions)
> On Fri, Sep 28, 2012 at 3:36 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
>> I was trying here:
>> Reported now. Thanks
>> Agus
>> On Fri, Sep 28, 2012 at 8:16 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>>> On 09/28/2012 10:28 AM, Agustin Lobo wrote:
>>>> I've tried to add a ticket for plugin "Add Pin" and get
>>>> "No tracker is associated to this project. Please check the Project settings."
>>>> if I have User plugins selected on the upper right corner
>>>> How do I open a ticket for this plugin that does not work (the point
>>>> is not drawn)
>>>> in 1.8. for linux? (works on mac and works with 1.7.4 on linux)
>>>> Agus
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Are you talking about the PinPoint plugin?
>>> Were you logged in? Once logged in do you see a New Issue menu item?
>>> It does appear to have a tracker but I might need to check the
>>> permissions on who can add Issues.
>>> Thanks,
>>> Alex
